Brake to Soft - 1992 F-350 C.C. 4X4
I recently purchased a 1992 F-350 CrewCab L.W 4X4, 460, E4OD, 3.55L, has 108,000 actual miles has never been worked in its life. My problem first started with a rear axle seal leaking, had my Chief mechanics do a rear brake job on it seals, wheel cylinders, brake shoes, turn drums, change oil in rear axle also the full rear brake job. The front brakes still have good pads a little pulsating in brake pedal not bad for a big truck. The brake pedal seems to fall to the floor very fast, so I replaced the master cylinder with a new one, it still doesn't stop the truck very quickly with out standing on it all the way kinda of scarey and it keeps dropping the pedal to the floor, brakes have been bleed several times. They won't pump up like if it was a weak master cylinder, even though it has a new one on it. Would it be a bad brake booster? I pulled the vaccum hose off and it had good vaccum also.
I just want good brakes on it like my 1995 Lightning has stop on a dime!!!
IDIDieselJohn
21
10-18-2015 06:38 AM
sixtires58
07-28-2010 09:13 AM
Butch(OH)
04-23-2008 05:14 PM
