New trans now o/d flashes
Old Apr 2, 2016 | 06:02 PM
tjbradney's Avatar
tjbradney
Well stock trans went two weeks ago so warranty company had another stock one put it (4r100). Finally got the truck today and I noticed my overdrive was flashing. I have no issues though shifts fine speedo works Rpms are normal I checked fuse 19 under the dash that's fine so I'm lost
If I turn the key on I can use the button like normal but once I drive it just flashes. It works but flashes .
Old Apr 2, 2016 | 06:15 PM
Pikachu's Avatar
Pikachu
If the light is flashing, there's a code stored. That's the best place to start.
Old Apr 2, 2016 | 06:19 PM
tjbradney's Avatar
tjbradney
Yeah I have a drive home tomorrow back to Delaware so Monday at work if it's still happening I'll have my one coworker scan it sucks you need a fancy scanner for it
Old Apr 2, 2016 | 06:21 PM
Rikster-7700's Avatar
Rikster-7700
You don't really need a "fancy" scanner, search for "torque pro" or "forscan" in this forum for some effective low cost options.
Old Apr 2, 2016 | 06:27 PM
tjbradney's Avatar
tjbradney
Well has to be fancier then the one I have lol
Old Apr 2, 2016 | 06:53 PM
tjbradney's Avatar
tjbradney
Just drove it to get food
I noticed it doesn't start to flash till I hit 15-20mph where it goes to shift to 2nd
But the code will tell just annoying that a dealership installed the trans and had to of seen this but of course they weren't there when I got it today
Old Apr 2, 2016 | 07:53 PM
z31freakify's Avatar
z31freakify
Did they replace the trans cooler and radiator? These are things overlooked when doing a transmission service, "cleaning/flushing" never works, replacement is necessary.
Old Apr 2, 2016 | 08:54 PM
tjbradney's Avatar
tjbradney
No they did not I plan to do a 6.0 cooler soon. They did have to replace two cooler lines due to them "blowing" after the new trans was installed. They said due to rust idk I didn't see the old lines and live out of state from where it was soo only so much i could do
Slash19
May 11, 2024 09:06 PM
HE11boy400
Dec 25, 2011 02:36 PM
1999SuperDutyStroke
21
Oct 14, 2010 02:41 PM
jeffdoerr
Feb 15, 2010 08:50 AM
TopGameHunter
Feb 6, 2007 09:20 PM
