flathead coil wire hook up-which one where?
Old 08-12-2003, 08:09 PM
F2fan's Avatar
F2fan
F2fan is offline
I got a new coil for my damaged one. just to be sure here can you help? Old coil had 2 wires, one marked batt, other marked dist, new coil has a - (neg) post and a + (pos) post. This is a 6v postivie ground system. which wire goes to what post? There is a gold plastic sleeve wire and a blue wire off the distributor. It is simple i know but I am having a brain lock today. Thanks for any help. RH
Old 08-12-2003, 10:14 PM
mtflat's Avatar
mtflat
mtflat is offline
On a positive ground system, the power supply (batt) goes to the (-) post. The (+) post is the ground and the wire goes from this to the bottom of the distributor.
Of course the heavy cable out the top of the coil goes to the center of the dist cap.
billdoss2
03-13-2017 12:45 PM
lostbrd
02-06-2017 01:37 PM
johnno5
6.2L V8
11-16-2016 06:48 AM
lawsonej
05-31-2016 07:40 AM
JimG1098
12-29-2015 07:03 PM
Quick Reply: flathead coil wire hook up-which one where?
