Electronic ignition wiring question
Old Feb 3, 2017 | 08:21 PM
lostbrd's Avatar
lostbrd
292 Yblock converted 6V to 12V.
Wiring is a mess and tough to trace which I will address in the near future, but for now I wanted to install the pertronix ignitor and have a couple questions.
Currently there are two wires on the positive side of the coil one comes from a
voltage reducer (I assume from ignition) the other not sure. There is one ground wire from distributor to neg side of coil. The new ignition has a red and black wire (red to + and black to - on coil per directions)
Should I end up with 3 wires connected to + side of coil.
Any help or explanation would be greatly appreciated.
Thank you
Jason
Old Feb 3, 2017 | 08:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Likely the wires are:
-- wire coming from ballast resistor is the "run" power feed from the ignition switch
-- the other wire may be coming from the "I" terminal on a 4-terminal starter solenoid. It bypasses the ballast during cranking to give a hotter spark for quicker starting. If you have a 3-terminal solenoid, then it could be for a tach or something else.
I believe with Pertronix you don't use a ballast or the bypass feed, but you should have gotten instructions with the system, or can find them on the internet.
Old Feb 4, 2017 | 10:41 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
No ballast resistor is used. PerTronix Instruction Sheets
Old Feb 4, 2017 | 10:55 AM
lostbrd's Avatar
lostbrd
So the wire coming from the resistor to the coil is terminated?
Old Feb 4, 2017 | 12:00 PM
bjmayberry2
Correct bypass the resistor and run full 12 volts to the coil.
Old Feb 4, 2017 | 01:55 PM
lostbrd's Avatar
lostbrd
Thanks All. Up and running!
Jason
Old Feb 6, 2017 | 01:23 PM
petemcl's Avatar
petemcl
Suggest that you use the Pertronix Flamethrower coil. Then you will need no ballast resistor. You will be much more satisfied with the results. Also I assume that you now have a negative ground?
Old Feb 6, 2017 | 01:37 PM
bjmayberry2
2X Pete! I'm using a Ignitor and Flamethrower III. Could call on the ground change too. Sometimes we (56ers) take these things for granted but the 53-55 folks are not negative ground from the factory.
ved0303
Jan 2, 2015 11:07 PM
fordguy76
Nov 14, 2011 09:36 AM
8525ford
Aug 24, 2009 08:51 PM
250-highboy-76
15
May 11, 2006 05:24 PM
Boss_358
Electrical Systems/Wiring
Nov 21, 2004 10:03 PM
