Sponsored by: Real Truck
Check Coolant Additive
Old Apr 15, 2017 | 09:26 AM
Pocket's Avatar
Pocket
Originally Posted by smr camper
saw this thread while searching online and it answered my question! I decided to join
Welcome! Stick around, there's a lot to learn.
Old May 12, 2017 | 11:24 AM
derbydog's Avatar
derbydog
Shelf life?
Originally Posted by Matthew Barnes
Thanks for all the help. I got my kit Friday and did my test and everything passed. It was very easy. Took me about 10 minutes, should go quicker next time I do it. The kit itself was $65 plus shipping and the dealership wanted to charge me $25 for the test.
Matthew - Thanks for sharing! What was the shelf life of the kit you bought? I am tempted to order one, but if the shelf life of the strips is only 6-12 months then I would basically be paying $65 for one test.
Old May 12, 2017 | 12:18 PM
az_r2d1's Avatar
az_r2d1
Originally Posted by Rasalas
Coolant tests go back many years. The early 6.9's and 7.3's were having erosion problems which caused perforations in the cylinder liners. A simply additive solved the problem, but I have never seen a test kit for that issue. I am sure there is one somewhere.
I thought it was cavitation issues. The vibration makes tiny bubbles that implode against the cooling walls slowly eating away the liner.
I'm shocked Ford still isn't using a better coolant.
There are coolants out there that last MUCH longer.
Old May 12, 2017 | 05:31 PM
Pocket's Avatar
Pocket
There are coolants that CLAIM to last longer. But under high-heat exposure like the EGR, they don't actually last that long.
Plus certain coolants, once they start to break down, become very acidic and/or corrosive.
Be very careful about switching to high-mileage coolant. Older diesels didn't have the emissions systems like today, so you could basically switch to just about any coolant (provided it was properly flushed) and drive as long as you wanted. With today's modern emissions, particularly the EGR which exposes coolant to excessively high heat, many high-mileage coolants don't hold up very well and actually can cause additional issues down the road.
Just FYI
Old May 12, 2017 | 05:32 PM
az_r2d1's Avatar
az_r2d1
Just FYI
Very good points. Thanks.
montauk1
6.7L Power Stroke Diesel
Apr 27, 2017 07:14 AM
rtazz17
19
Sep 6, 2016 10:57 AM
PltnmThndr
Mar 26, 2016 05:00 PM
teppler
Jan 29, 2010 06:37 PM
d_stange
Jul 27, 2006 08:26 PM
