We Own Work: My 2017 Super Duty Experience
#1486
#1488
I just dropped out of electronic engineering. couldn't recall all the algebra and was too difficult playing catch up.
#1491
Yes unfortunately the Algebra keeps some good students out of electronics. One you finish the courses you never use it much as a technician except simple Ohm's law and Kirchoff's Law stuff in your head, it's just hard to teach electronics without math.
We teach you the theory, then have you do math problems to prove the theory is right, then lab experiments to see it in the real world.....
#1492
If you liked calculus, you might want to consider sticking it out for a while. Many excellent scientists didn't really enjoy or excel in the pre-calculus math.
#1493
#1494
I agree. Not only is America dumbing down as far as most of the younger guys not having any technical skills or common sense but when somebody needs a trailer backup system to tell them which way to turn the wheel to back up...
If they need that system they don't need a SD and probably not even a F150.
Not all of us younger folk are as such, in fact I mostly hear such complaints from people who also can't figure out how to answer their phone
That said, I also grew up in construction and got a degree in computering (technical term there.) so I might be a special case.
It gets a little old hearing people bitch about us "younger folk". I have had the pleasure of working almost exclusively with people of all ages who are dedicated and intelligent, willing and quick to pick up the basics of new skills and seek challenges. Regarding trailering: I've been pushing trailers around my whole life, and most of my dad's employees would ask me to get them out of any tight spots. A sampling of said employees doesn't show any correlation between age and trailer skill.
I think the ones who need the assisting technology tend to be those whose parents were successful, and as such they have always had money and never had to work around trailers, but have decided they should own a boat.
Still haven't talked to anyone who liked it, though. With the same technology they could have given the truck a remote control, which would be _AWESOME_ for things like hooking up trailers or dumping a load of mulch/gravel while dodging power lines and kids on tricycles not paying attention to what's around them.
Archer,
Go to the build and price for the 2017. You can spec a radio without the 4.3" screen. It is basically a 1 or 2 line dot matrix display. The instrument panel is the 2.3" display on the most basic trucks. As in Josh's pic, you can certainly get the large radio screen in an XL.
Got a bit long winded there, sorry.
#1495
Yeah, I saw that too, but wasn't sure whether or not to believe it. I'm going to try to build an in car computer as my next challenge, trying to figure out what my base is, hoping _not_ to have the screen. The F-150 base trucks I sat in all had the screen regardless of trim level so seems a bit surprising they'd build one without, though I hope it's accurate!
#1496
Lance Cripple Racing- a motorcycle racing team I run in the CMRA here in Texas. Lance Cripple refers to when I picked up the rank Lance Corporal while in rehab with a few broken bones.
I loathe math in general, Since the oil layoff I'm finishing up some logistics certs and will explore the algebra again. I would really like to finish up engineering even if I go into something like industrial.
I was originally classed as aviation ordnance and electrician in the Marines before I got put in the logistics shop for a few years and electrical theory was easy enough for me to understand. It really is discouraging though with the dozens of engineers I've worked with who all say the math isn't really needed because computer programs do it all now, they just want you to understands the theories and show you can apply them purposefully in problem solving.
I was wondering if your username stood for inductor, capacitor and resistor, now I know it does.
#1497
#1498
#1500
on
I personally think it is related to the two piece shaft and driveline angles.. Either the center carrier bearing needs to move up/down or the tailshaft of the tranny needs to. That's my suspicion at any rate...
I had a bit of the take-off shudder when loaded but after I added air bags, that went almost totally away.
The take off shudder while towing should be gone from what I recall. that is the shudder we did a lot of extensive testing on a few years ago with the shim changes and what not. The other shudder you speak of Randy, I'm not fully aware of. but again, most of that would go to the NVH guys.
Yup, I can see how changing pinion angle can help the driveline shudder on take-off. Unless Ford comes out with a TSB for the older trucks, we're going to be stuck with it unless we make the changes ourselves. Most dealers just shrug their shoulders and tell you they did not observe the problem.
There can also be problems under torque with axle "wind up" where the torque tries to rotate the entire axle on the springs, and then the springs react and the axle snaps back to position and then the torque starts to pull it down again. Heavy trucks used to have a link from the frame to the top of the rear end to stop that wind up. The link had rubber bushings on each end and seemed to wear quickly (200K miles) and were affectionately known as "dog bones" due to their shape.
The 42 mph shudder would not involve axle wind-up / torque as it happens even unloaded when decelerating from a higher speed..
I think you may be addressing the acceleration from a dead stop shudder when loaded. My bags seemed to have taken care of literally all of it but a faint quiver.. My trailer is almost 19k and pin weight is 4910#
