IP diagram
Old Mar 30, 2016 | 05:14 PM
Nathan Cox's Avatar
Nathan Cox
IP diagram
Any one have a injector pump diagram handy. I heard there is a spring in the top that sticks closed. For some reason the truck has fuel coming in the pump going out the return line but can't seem to get it to all the injectors. Only 4 are looting out fuel? Any ideas tried fuel treatment and a little atf.
Old Mar 30, 2016 | 05:31 PM
Fixnstuff's Avatar
Fixnstuff
You can go to the following URL and download the DB2 Injection Pump Operation and Instruction Manual and Torque Specifications both in .pdf near the bottom of the list:
Index of /Ford
Old Mar 30, 2016 | 07:53 PM
Macrobb's Avatar
Macrobb
This here is probably the best visual reference we have:
That video is great; the only difference between that and our pumps is we have a light-load advance cam pushing on the cam advance pin at the bottom.
Old Apr 3, 2016 | 04:04 AM
fordtrucksforever's Avatar
fordtrucksforever
I looked all over for a Service Manual to address an injector pump from a John Deere 50 kva three phase generator. Its a Roosa JDB model. I finally found one. Tore the pump apart and scrubbed out the dried diesel varnish residue thats been sitting since new 30 years ago. I didnt realize until downloaded the DB2 manual for my 6.9 that its basically the same pump. Almost identical in regards to disassembly and components. Adjustments vary, but not an issue. After going thru the John Deere pump, I am not so apprehensive about working on the truck pump if the need arises.
McQ
Jun 22, 2012 07:20 PM
Service462
General Diesel Discussion
Jul 30, 2009 10:01 PM
John311t
Oct 18, 2007 11:27 PM
f100guy
Apr 12, 2007 09:25 PM
puman350
Apr 21, 2002 07:33 AM
