VSS - keep or what...
Old Mar 30, 2016 | 02:16 PM
jrodimus's Avatar
jrodimus
Rebuilding a sterling 10.5. Doing a hydroboost brake swap. Disc brake swap on the sterling. Do i need the tone ring for anything other than ABS? I thought speedo gear is in t-case. I would like to not use the tone ring as the old one is damaged and I dont want to get another.
Old Mar 30, 2016 | 03:08 PM
subford's Avatar
subford
In a 1991 the tone ring is only used for the RABS.
So I would say you do not need it.
Old Mar 30, 2016 | 08:01 PM
Conanski's Avatar
Conanski
What transmission? If the truck has a manual or C6 you are clear but if it's got an E4OD then maybe not. I know the speedo is cable driven in a '91 but I'm not certain where the electrical speed signal for the PCM is derived from.. if it also comes from the trans or t-case or if it comes from the rear axle sensor as it does in the later trucks.
Shiro Elex
Oct 31, 2015 12:03 AM
lisagoud
Apr 21, 2012 03:36 PM
hawaiian-style
Apr 11, 2008 10:46 AM
dieseldoc
Aug 28, 2006 02:51 PM
RoadRash
Aug 23, 2002 04:45 PM
