Dash Cam Vehicle Rollover
Old Mar 29, 2016 | 10:45 PM
robert_l_ross's Avatar
robert_l_ross
...happened about 10-15 minutes before I drove by...all three CHP officers, the Sheriff and the AMR rig passed me to get to the scene.
Lucky he didn't go over the causeway - it's a good 20 foot drop into a still-flooded area. Could have been much, MUCH worse.
Front Cam:
Rear Cam:
Old Mar 30, 2016 | 07:13 AM
ExxWhy's Avatar
ExxWhy
Had me worried it was you!
Camera seems to work pretty good.
Old Mar 30, 2016 | 03:17 PM
Patriotic Rottweiler's Avatar
Cameras look awesome.
Old Mar 30, 2016 | 08:58 PM
pirate4x4_camo's Avatar
pirate4x4_camo
lol @ me, I was watching that and realized I know where that is... hmmm
then I see you are from my neck of the woods. doh guess I need to pay more attention.
Old Mar 30, 2016 | 09:24 PM
The2003Excursion's Avatar
The2003Excursion
Which camera do you have?
Old Mar 31, 2016 | 12:31 AM
robert_l_ross
BlackVue DR650GW dual cam. VERY happy with mine.
Old Mar 31, 2016 | 01:16 AM
Watcher58's Avatar
Watcher58
BlackVue DR650GW Daylight - YouTube
BlackVue DR650GW Night Footage - YouTube
Looks like your X is tracking pretty straight.
Unlike my ending upside down, I do not believe there was any black ice involved in this incident
Old Mar 31, 2016 | 05:49 AM
carbon coupe's Avatar
carbon coupe
Can you show how/where you mounted these?
Old Mar 31, 2016 | 02:53 PM
Yes, if possible do a video of your system/installation. And why you choose the system and installation locations that you did and how it is wired.
Old Mar 31, 2016 | 05:19 PM
Stewart_H's Avatar
Stewart_H
You can see a little bit of info from his posts here: https://www.ford-trucks.com/forums/1...l#post15870665
Stewart
Old Apr 1, 2016 | 12:59 AM
robert_l_ross
Sure guys, give me a day or two. I mounted the front cam directly under the rear view mirror. The rear cam is mounted as high as I could get it on the back glass. I run a wiper a little longer than usual and it clears the water/mist from directly in front of the camera.
You have to mount these directly to the windows...if you try to mount them to the trim, they'll vibrate.
Wiring is dirt simple. You can just wire in a cig adapter and hide it, but the cam would either run all the time or only when the key is on. They make a little box that lets you set the timing to be X hours after key off, or until the battery goes below X volts.
That box is easy to mount...one wire to an always-on wire, another go a key-on wire, one to ground. It has it's own cig port and some dip switches to your liking. You can do all this using the add-a-tap type fuse clips if you want.
I'll do a quick video tomorrow after work or Saturday and post it for you guys.
ng19delta
15
Jan 1, 2017 04:51 PM
Shwan_89HD
18
Apr 14, 2012 05:34 PM
