Won't pass smog, p0156 error code...
Old Mar 29, 2016 | 08:59 PM
Janice44's Avatar
Janice44
2004 exped., 4.6 liter. error code p0156, bank 2, sensor 2. Replaced sensor, drove, error code came back. Replaced the three other sensors, code came back on. Wiring to the sensors appears good, but one of the wires might be hanging low. This will be checked. We are trying to figure this out before going to a shop. Mechanics, we are not. Anyone have ideas? Truck has 152k miles. Cat converters have not been changed.
Old Mar 29, 2016 | 11:27 PM
85e150's Avatar
85e150
Check for a vacuum leak. Sometimes you get a sensor code due to another problem and intake leaks are a common source of codes that look like the sensor is bad or something else.
Old Mar 30, 2016 | 01:42 PM
projectSHO89's Avatar
projectSHO89
A vacuum leak cannot cause this particular DTC although an exhaust leak can.
The DTC indicates that the output of the sensor S22 is "stuck", either high or low, and is not changing. Have your mechanic check and see if that signal line is shorted to either ground or some other wire. He should be able to monitor the sensor output on his scan tool to see where it's stuck at. That will give him more data.
There was nothing wrong with the other three sensors, they should not have even been considered as suspects for this particular fault.
xc4jokestomper
Feb 7, 2012 05:02 PM
cdawley1
1997 - 2003 F150
Feb 3, 2010 02:44 AM
drifter
Jul 25, 2007 08:04 PM
tapout
1997 - 2003 F150
Oct 3, 2006 12:29 AM
Mike's250
Modular V10 (6.8l)
Jun 28, 2005 09:12 PM
