Code P0153
Old Jul 8, 2007 | 03:03 PM
drifter's Avatar
drifter
Code P0153
My wife's 98 Explorer's CEL came on and when I checked for codes I came up with P0153. From what I've read it is the O2 sensor on drivers side that's bad. I also read that an exhaust leak could cause this code to come up. Her Explorer needs a new tailpipe as it's has a hole in the bend right after the muffler. Could this leak be the cause or is it more likely the O2 sensor? Any help would be appreciated. Thanks
Old Jul 25, 2007 | 08:04 PM
amish77's Avatar
amish77
the leak causing the o2 sensor failure likely has to be upstream of the o2 to cause this code. Downstream should have little to no effect.
