Intermittent wipers
Old Mar 29, 2016 | 08:02 PM
black & blue 78/9's Avatar
black & blue 78/9
Intermittent wipers
I NOW have intermittent wipers on my 79 Bronco. Thanks to the stickies. I bought the stuff at the jy from an 88 f150 and it was a plug and play. Even the washer pump works without changing wire pins. Straight p&p. Even got the door switches for the dome light to work. Happy happy happy happy happy
Old Mar 29, 2016 | 10:21 PM
march's Avatar
march
5 stars for reading the stickies.
That's something you don't see everyday. I live in fear that I will post a question only to find out Rich put the answer on page 403 of his "info and then some" stickie...............
Enjoy the intermittent wipers. I couldn't live without them here in the Pacific NW.
Old Mar 29, 2016 | 10:46 PM
TheSterling's Avatar
TheSterling
I recently just upgraded mine too! No washer pump though... How hard is it to install a washer pump?
Old Mar 29, 2016 | 11:50 PM
mark a.'s Avatar
mark a.
That's nice
Old Mar 30, 2016 | 01:27 AM
black & blue 78/9
The washer pump was working before the upgrade. Based on the stickies I read, I thought I would have to move a wire in the connector, but this 88 version I did not need to.
Old Mar 30, 2016 | 01:47 AM
burnthelight88's Avatar
burnthelight88
Washer pump is super easy to replace. You pull the washer reservoir from the engine bay, disconnect the plug, remove the lock ring, swap in the new one. Replace the fluid hose while you're at it, I think its about 2 feet long. By this point in your trucks life, it's probably cracked. That's all there is to it, takes about 10 minutes.
To the OP, you should do the wiper upgrade that's also somewhere in the stickies, or just search it. Best combo upgrade (intermittent/wiper) that I've done to the truck thus far. Those stickies sure are useful if you have time to sort through them.
Old Mar 30, 2016 | 07:49 AM
HoustonDave's Avatar
HoustonDave
One of my happier days: I thought my wiper switch was shot because it rotated past the stop detente - then the wipers moved and I realized I had intermittents!! WhooHoo! Unfortunately I have no juice on the white wire when I push the washer button, so I suspect the switch is partially bad anyway... but yeah, intermittent wipers rank up there with the best of automotive conveniences.
Old Mar 30, 2016 | 11:19 AM
CelticOne's Avatar
CelticOne
Regular User
Someone may have swapped in an intermittent switch from the '80s and not changed the wire for the washer pump as stated above. Check with an electrical tester or simply swap the two wires on the smaller part of the plug (if my memory serves me).
Old Mar 30, 2016 | 11:39 AM
HoustonDave
Can't think of one reason not to try this... I checked the juice at the wire but never thought to check any open terminal. Learn something new every day- Thanks!
Old Mar 31, 2016 | 04:37 AM
burnthelight88
I didn't have to swap any wires in mine either and everything works perfectly. I can't remember what year mine came out of though, but I believe it was mid-80s. Is swapping a wire a thing for certain years? I hadn't heard of that at all, thought they were all plug and play...?
Old Mar 31, 2016 | 09:21 AM
tinman52's Avatar
tinman52
Welder User
Can someone post a link to the article or tech thread? I really need to do this upgrade on my '79...!
Old Mar 31, 2016 | 09:56 AM
CelticOne's Avatar
CelticOne
Regular User
Old Mar 31, 2016 | 06:40 PM
tinman52's Avatar
tinman52
Welder User
Thanks! That looks really simple.
NavigateNate
Jan 6, 2018 08:45 AM
ligito
Aug 22, 2017 11:28 AM
marcusfreed2010
Nov 26, 2013 11:01 PM
eclectix
19
Aug 18, 2003 12:50 AM
