I would like to know the best combo for a 429 with a tunnel ram. What is the best cam, carbs, etc. I would like everything to match so I can get the max. horsepower. Thank you.
We will need a bunch more info.
Which intake is it?
What heads and do you know how much they flow?
Compression ratio?
Header dimensions?
Intended rpm range?
How much does you rig weigh?
Gear ratio?
Converter speed or is this a manual?
Intended usage…….Street, strip, boat, puller, bogger, show?
