Blower only runs on high??
Old Jul 10, 2003 | 07:40 PM
dbuck50's Avatar
dbuck50
My interior blower only runs if I switch it to "High", doesn't matter if it is A/C or just heat/vents. I replaced the control switch in the dashboard, but that wasn't it. The only other thing I notice is that when I shut it off from high, I can hear the blower motor make a rumble like the edges are hitting something? Could the blower motor be the problem, or is there another control somewhere else that could be bad.
it's a 93 F150
Old Jul 10, 2003 | 11:14 PM
Mr Man's Avatar
Mr Man
Sounds like your blower resistor. A faulty resistor will cause one or more lower fan speeds to stop working, while high fan speed will work fine.
Old Jul 10, 2003 | 11:22 PM
steve83's Avatar
steve83
I agree that it's probably the resistors, but the noise may mean it's full of leaves. Pull the blower motor out & reach inside. If it's got leaves in it, pull the evaporator cover & evap core, and hose it all out. It'll give you an opportunity to recover all the pens & change that has fallen down your defrost registers.
03F250SD
Apr 26, 2015 12:42 PM
cbrguy
1997 - 2003 F150
Jun 12, 2011 09:52 PM
drpratt
Apr 14, 2009 09:50 AM
fordblue_ca
Nov 7, 2003 02:41 PM
wrenched
Apr 28, 2001 07:55 AM
