Glow shift boost gage
Old Mar 28, 2016 | 11:55 PM
bettywhite's Avatar
bettywhite
I've got a 1997 f250 7.3 that I bought a few weeks ago and it's got some glow shift gauges and they are all hooked up except for the boost gauge. Anyone now how to hook it up without drilling a hole in my turbo?
Old Mar 29, 2016 | 12:05 AM
fordman67's Avatar
fordman67
T into the map sensor hose on pass side of engine
Old Mar 29, 2016 | 12:15 AM
Hutch17's Avatar
Hutch17
only problem with that is I've heard it doesn't read accurately and only reads to a certain amount
Old Mar 29, 2016 | 12:41 AM
bettywhite's Avatar
bettywhite
Are the glow shift mechanical or electrical? Because the guy that installed the gauges didn't do it very well and I can't find any wire or house coming from the firewall for the boost gauge
Old Mar 29, 2016 | 12:50 AM
Kingkong0192's Avatar
Kingkong0192
He probably bought the glowshift kit like i did and never hooked the boost gauge up. Probably just slid the gauge into place so it wouldn't be empty.
I think there's three wires coming from the back of the boost gauge, a switched 12v and then a trigger wire that tells the gauge the headlights came on and it dims the gauge brightness 30%, and then a ground.
As for the actual boost, it's mechanical. There's a small line that runs (or should be run) from the back of the gauge to wherever you're tapping into for boost pressure.
Old Mar 29, 2016 | 01:04 AM
bettywhite's Avatar
bettywhite
Thank you, I'll look for the hose or wire for the gauge tomorrow
Old Mar 29, 2016 | 06:36 AM
fordman67's Avatar
fordman67
I don't know how it would read only some. The nipple is not restricted. There are plenty that hook theirs up like that. If that's not correct then how would the map accurately tell PCM the fueling strategy under boost?
I personally tig'g a boss into my outlet pipe from the turbo. Not everyone has that ability tho so I did not suggest it.
Old Mar 29, 2016 | 11:47 AM
bettywhite's Avatar
bettywhite
Yeah I'm looking to keep it simple cause I don't want to mess anything up.
Where exactly is my map sensor?
Old Mar 29, 2016 | 12:23 PM
Kingkong0192
Firewall about 10'oclock if you're standing dead smack center of your truck looking at the engine bay from the front.
There's a vacuum line running to it.
Old Mar 29, 2016 | 02:06 PM
fordpride's Avatar
fordpride
This is 99-03 but map is in the same place
Old Mar 29, 2016 | 09:54 PM
bettywhite's Avatar
bettywhite
Thanks guys, I found the map sensor and the vacuum line but I can't find any of the wires coming from the gauge cluster
Old Mar 29, 2016 | 09:59 PM
z31freakify's Avatar
z31freakify
There shouldnt be any wires just a vaccum hose t'ed to it.
Old Mar 29, 2016 | 10:03 PM
bettywhite's Avatar
bettywhite
Alright, I'll go ahead and see if he even put a vacuum hose on it. Thanks for the help guys
Old Mar 30, 2016 | 06:36 AM
fordpride's Avatar
fordpride
http://www.ebay.com/itm/like/361285490094?lpid=82&chn=ps&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D53601919689_324272%2526itemid%253D361285490094%2526targetid%253D173528746809%2526rpc%253D0.22%2526rpc_upld_id%253D67155%2526device%253Dm%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fulk%25252Fitm%25252Flike%25252F361285490094%25253Flpid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526googleloc%253D1026339%2526poi%253D9025354%2526campaignid%253D239125209%2526adgroupid%253D14978428809%2526rlsatarget%253Dpla-173528746809%2526gclid%253DCj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzWy09htOpqbOtyP8-iqLwyq9iktzk7xx-7UYdJGDjaIaAohr8P8HAQ%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1006521665297&ul_noapp=true
muskydawg
Jan 28, 2017 07:23 PM
flaboy63
May 28, 2013 01:23 AM
charger6t9r
Apr 26, 2013 07:53 PM
koski19
Apr 3, 2013 05:14 PM
hookd
Sep 16, 2006 03:26 PM
