HELP 6.0
Old Mar 27, 2016 | 02:30 PM
cpapas's Avatar
cpapas
HELP 6.0
Has ne one seen fuel injectors do this? they are off a 2006 Ford F350 dually with the 6.0 diesel motor! Have replaced all 8 fuel injectors got back drove for 200miles and fuel injectors 4 and 8 were throwing codes changed them out and high pressure oil pump oil coolant deleted egr valve changed the ipr valve feed tubes to the oil rails. replaced the FICM. Yet again drove for 2 days about 200 miles again and shut down (stalled) misfiring hard start. and now fuel injector 4 is throwing codes again. Have not drove it since we got it home from the last stall out which was a few feet from our drive way and we towed it home. any information would be nice been researching possible things and it could be from fuel pump to god knows what we have over $7000 in just parts for this truck and havent even owned a year yet.
Old Mar 27, 2016 | 03:16 PM
BLADE35's Avatar
BLADE35
did a shop do work
Old Mar 27, 2016 | 03:24 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Also, what codes are specifically being thrown?
Old Mar 27, 2016 | 03:28 PM
cpapas's Avatar
cpapas
Yes and it's endless they say nothing else is wrong with it. And as codes all I was told was it was the code for the number 4 fi
Old Mar 27, 2016 | 03:46 PM
BLADE35's Avatar
BLADE35
are all the inject coming apart like that
or so the shop says id likely ditch that shop
you need a code reader we need codes it would also help to get something to see live data we can give a pretty accurate answer to problem and atleast keep the shop from throwing uneeded parts at it
Old Mar 27, 2016 | 04:29 PM
cpapas's Avatar
cpapas
The first time it was two of them that pulled apart like that I don't remember the numbers in the line up I want 5o say 2 N 3 or 3 N 5. I will c if I can get the codes from them tomorrow as they aren't open today
Capt couey
Aug 10, 2012 12:01 AM
Smokey1
Feb 14, 2010 11:05 AM
paddlesplash
Dec 21, 2009 04:50 PM
williehood
Oct 6, 2009 03:25 PM
topdrive
Jul 13, 2009 05:54 PM
