Programmed keypad, now fob doesn't work
Old Mar 26, 2016 | 08:32 PM
tracyclifton's Avatar
tracyclifton
I did a search but couldn't find this particular problem. We bought a 2006 Explorer today. the dealer gave us a new unused key fob because it did not have any. We followed the 8 times to on procedure and it programmed the key fob perfectly. Then we programmed the keypad on the door and it worked great. However, after the keypad was programmed, the key fob stopped working. When we try the 8 times on procedure, now it locks and unlocks the doors twice and the key fob never gets programmed. Has anyone seen this before? It has us baffled. Thanks in advance for any help.
Old Mar 27, 2016 | 07:57 AM
tracyclifton
After about an hour of frustration, I took the key fob apart and discovered that the battery wasn't making good contact. I bent the little contacts out and got the fob working. So it wasn't the truck, just the fob stopped working after the first few uses. All is well.
Old Mar 27, 2016 | 09:29 PM
shorod's Avatar
shorod
That was a easy, inexpensive fix for you. Odd coincidental timing. Thank you for following up with what you discovered!
-Rod
Old Mar 28, 2016 | 08:22 AM
tracyclifton
Still frustrating. What should have taken 2 minutes turned into over an hour. At least the new stereo installation went a lot smoother.
shadow460
2009 - 2014 F150
Jun 23, 2019 09:35 AM
tunastick
Feb 4, 2016 01:25 AM
Calixto
1997 - 2003 F150
Nov 9, 2014 01:09 AM
marcogyver
15
Jul 26, 2014 11:57 PM
cedman
Nov 4, 2008 03:22 PM
