Key programming issue or non chipped key
Old Feb 3, 2016 | 07:20 PM
tunastick's Avatar
tunastick
When I bought my 02 F350 it only came with one key that was an all metal (no chip) key. The truck starts and drives. All of my research tells me that my truck should have chipped keys and should not even start without one. I ordered two chipped keys and fobs had the keys cut and went to the dealer for programming, the guy in the shop said it cannot possibly be chipped if it is running and driving without a chipped key. He also said that some of these trucks were chipped and some were not...that sounds strange/inaccurate to me. The truck did have an aftermarket security system in it when I got it but has since been removed. Did some of these trucks leave the factory without this feature? Could the security system have been bypassing this feature? I also thought that certain functions would not work without a paired key. The truck did come with one fob that partially works...it unlocks but will not lock the truck so I have to go around to all four doors and lock them manually which is getting old. Does anyone else have a truck without chipped keys or a similar issue? This is the last little kink I'm trying to straighten out on my truck and any help would be GREATLY appreciated.
Old Feb 3, 2016 | 07:26 PM
coax9952's Avatar
coax9952
My 02 F250 doesn't have a chip, runs on a metal key, Has Key Fobs......Never had a chipped key, nor have I ever heard of one in our year...
Old Feb 3, 2016 | 07:32 PM
petrokiller's Avatar
petrokiller
I 2nd not having chipped keys on our era of Superduty's.
You can check to see if you have remote entry though.
Listen while you do these steps.
Cycle your key in ignition to on/off 8-12 times without starting the truck.
If you have remote door locks they will cycle up and down.
Then if they do cycle you just order Key Fobs from Ebay and program them.
I too only had one metal key. Did the test because I have power locks. $20 later and a few days I have remotes.
Old Feb 3, 2016 | 07:43 PM
tunastick's Avatar
tunastick
I have two new fobs just haven't tried to program them yet. I think there is something going on with my rear driver's side door I have already tried replacing the ajar switch but I suspect the mechanism is the problem now as the doors will unlock with the fob but not lock. Thanks for the replies on the keys!
Old Feb 3, 2016 | 08:16 PM
F350-6's Avatar
F350-6
I took delivery of my 02 from the factory. No chipped key here either.
The excursions did come with a chipped key though.
Old Feb 3, 2016 | 08:20 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
I also have a 02 with non-chipped keys. Spray mechanisms down really good on all doors w/ PB Blaster. I have had bad FOB's right out of box. We go through a lot of them.
Old Feb 3, 2016 | 09:03 PM
dsltech83's Avatar
dsltech83
PATS was an option that not many trucks got. Became standard in 08. All Excursion models had PATS.
Old Feb 3, 2016 | 10:22 PM
petrokiller
Get on eBay and buy a set of 4 12v universal door lock actuators. I put them in my Crew cab and love them. Good and strong. $20
First I did the tinfoil mod. Somehow all 4 actuators cooked while at mechanic.
Old Feb 4, 2016 | 01:25 AM
Stewart_H's Avatar
Stewart_H
I think maybe you might have confused the info as it applies to the 7.3L powered Excursions and not the SuperDuty trucks.
The Excursions are chipped, the trucks aren't.
Stewart
90pioneer
6.7L Power Stroke Diesel
17
Apr 23, 2024 03:10 PM
st.rodder2
Nov 13, 2020 05:55 AM
2civicrr
19
Apr 10, 2018 11:00 PM
94xltsc
Nov 26, 2014 05:40 PM
clogee
1997 - 2003 F150
Nov 30, 2003 10:32 AM
