Keyless Entry Code
Old Mar 26, 2016 | 10:20 AM
WyoX's Avatar
WyoX
Keyless Entry Code
Cleared off the previous owners door entry code, (he wrote it in the owners manual) and went to set my personal code and it did not take.
The factory code card is also in the manual, so I have all the numbers I need. Tried it several times. Made sure I didn't punch in a number that uses the same pad twice.
It won't even open using the factory code now either. I read through the key less entry code thread in the tech folder, but it didn't mention anything about what I am experiencing.
This is the first vehicle I have owned with a keyless entry pad and want to use it. I am moving up in the world.
2002 Limited 6.8 V-10
Old Mar 26, 2016 | 11:02 AM
mecdac's Avatar
mecdac
Is there anything "wrong" with the factory code?
IMO, the factory code would be harder (for someone) to guess than a personal code.
Old Mar 26, 2016 | 11:21 AM
WyoX's Avatar
WyoX
Yes, I could use the factory code, but it won't program in either. This is why I was wondering if there is a way to get it to work.
I am following the easy instructions in the manual to get it to the factory default, but it is not taking.
Would pulling the neg. battery cable do any good to see if that clears it?
Old Mar 26, 2016 | 06:48 PM
Apocalypse's Avatar
Apocalypse
Pulling the battery cable couldn't hurt. All it does is reset everything that isn't hard programmed into the system. Sadly I'm pretty sure it won't help as if it did a dead battery would reset everything on someones car that had the keypad and everyone would be pissed. It is however worth a shot!
Old Mar 26, 2016 | 10:34 PM
1 Excursion camper's Avatar
1 Excursion camper
I definitely couldn't hurt to disconnect the battery. It's a computer after all and we know those can get hung up/stuck once in a while. Or it may have locked you out after so may tries. I thought I heard that they do that, but I never looked into it.
Old Mar 27, 2016 | 08:21 AM
Apocalypse's Avatar
Apocalypse
The 05's do, but not the 04 and down IIRC.
Old Mar 27, 2016 | 09:53 AM
WyoX's Avatar
WyoX
Thanks for the replies. I will give it a shot and let you know.
Haven't had time to mess with it the last few days. Been working on firearms. I have priorities.
Old Mar 27, 2016 | 09:23 PM
Stewart_H's Avatar
Stewart_H
Can you post a pic of it so we can make sure you have an OEM factory installed keypad and not one of the battery operated ones you can buy from the dealership.
Stewart
Old Mar 27, 2016 | 09:59 PM
WyoX's Avatar
WyoX
Stewart
Here you go.
Old Mar 27, 2016 | 10:08 PM
Stewart_H's Avatar
Stewart_H
Thanks, that's OEM from factory.
Stewart
Harley320
Jul 12, 2008 12:33 PM
jmccpa
Sep 30, 2006 08:11 PM
Harrski
2004 - 2008 F150
13
Jun 11, 2006 05:56 PM
automaticj5
1997 - 2003 F150
Jul 28, 2005 04:06 PM
dthndmills
Sep 23, 2002 11:45 AM
