Throttle pos sensor on 6.9?
Old Mar 24, 2016 | 06:10 PM
bpimm's Avatar
bpimm
What throttle position sensor fits on the injection pump on the 6.9?
Also how many magnets are on the injector gear for the tach sensor and does it rotate at crank speed or a multiple of crank speed?
Thanks
Old Mar 24, 2016 | 08:58 PM
Macrobb's Avatar
Macrobb
If you're trying to do something computerized, you'd probably best just rig up a variable resistor or rotary encoder. The 6.9 and 7.3 pumps are identical, so you could use a TPS from a E4OD, it's an electrical unit. The 6.9s all had c6 transmissions, which use a vacuum regulator valve attached to the shaft.
There is only one magnet - inside the sensor itself. It creates a pulse for every tooth on the gear.
The gear rotates at cam speed, or 1/2 of crank speed. The gear has 106 teeth, so you need to divide by 53 to get 1 pulse/rev.
Old Mar 24, 2016 | 09:01 PM
Ford_Six's Avatar
Ford_Six
The TPS for the 7.3 fits there. There are no magnets on the pump gear, the tach sensor reads the teeth on the gear. It spins at half crank speed, 106 teeth I believe.
On edit- I see Rob beat me to the response.
Old Mar 25, 2016 | 08:52 AM
IDIoit's Avatar
IDIoit
IP gear is 106 teef.
spins at 1/2 crank speed
as posted.
verified by my VDO tach
Old Mar 25, 2016 | 01:31 PM
bpimm's Avatar
bpimm
Thanks guys, just what I needed.
desertt5
Sep 27, 2010 10:17 PM
danlee
Apr 12, 2010 01:52 PM
SmokeyF350
Jul 1, 2009 11:51 PM
lciambotti
Dec 16, 2008 04:40 PM
brownawell1
General Diesel Discussion
Oct 18, 2007 09:36 AM
