No Start Below 55 Degrees
Old 03-26-2016, 09:26 PM
FICMrepair.com's Avatar
FICMrepair.com
FICMrepair.com is offline
Former Vendor
Originally Posted by papatioman
I was scratching my head on that too until I learned I had tested it wrong. Looks like the reading I was getting was the input voltage to the FICM. Recommendations on an oil filter brand?
Motorcraft.
Old 03-26-2016, 09:32 PM
Tideman's Avatar
Tideman
Tideman is offline
Motorcraft filter. Make sure you have the right oil cap (OEM ) not the tall one.
Old 03-26-2016, 09:35 PM
papatioman's Avatar
papatioman
papatioman is offline
Thanks for the input....I will get it all figured out......
Old 03-27-2016, 06:24 PM
papatioman's Avatar
papatioman
Updated readings on the FICM voltage output. 47.9 at key on and 22.7 while running. Need the truck this week.....will pull out next weekend and send in for repair.
Old 03-27-2016, 06:40 PM
TooHuge's Avatar
TooHuge
TooHuge is offline
Wow I thought mine was bad when I replaced it. Mine was 40v at idle and 33ish on WOT and my truck was running like dog #$%$.
Glad you figured it out, but the longer you drive it like that the more damage you are doing to those injectors $$$$
Old 03-27-2016, 06:53 PM
papatioman's Avatar
papatioman
I need it one day this week for about 2 hours. What's odd is it purrs like a tiger and runs smooth all day long.
Old 04-14-2016, 09:40 PM
papatioman's Avatar
papatioman
UPDATE: Sent my FCIM off to FCIMRepair.com last week. I was thinking when I sent it off "now a really good company would send it back cleaned up". Well........got it back Wednesday and it looked brand spankin new. Got it put back in this evening and the old girl fired right up after sitting for 12 days. Ambient air temperature was 57 degrees. The true test will be in the morning when the temps are lower. Great job FCIMRepair.com!
Old 04-15-2016, 12:37 AM
FICMrepair.com
Former Vendor
Woot! Glad to be of service! Let us know if you need anything else for your 6.0. We carry everything you can get from your local Ford dealer and nearly everything you can get in the aftermarket space - just for less money!!
powerstroke84
13
02-01-2015 10:05 AM
tap1946
01-17-2012 07:33 PM
DiesalBoyz2000
13
02-20-2011 09:30 AM
offshore$al
1999 to 2016 Super Duty
12-06-2010 01:55 PM
F-250 diesel
12-22-2004 06:05 AM
Quick Reply: No Start Below 55 Degrees
