Battery.....when is it time to replace?
Old Mar 24, 2016 | 07:50 AM
SoCalAngler's Avatar
SoCalAngler
I just noticed during the last month that when attempting to start my truck (turning the ignition key) it doesn't do anything for the first 2-3 attempts. I try again, it doesn't do anything. And then after a second or third third time it starts right up. All dash lights come on each time, but engine doesn't turn over until after 2-3 attempts.
The battery is from Costco and has a date sticker of 12/13.
So it is 2 yrs/3mos old.
I checked all battery connections and made sure everything was tight. I don't drive the truck daily, about once per week.
Does this sound like a batery going bad? Ir what else?
Getting ready to go on a trip towing my trailer and was concerned about the battery. I guess I can remove the batt and take it down to the parts house and have them check it. Will they do a load test? Does batt have to be 100% charged?
Thanks
Old Mar 24, 2016 | 08:28 AM
MI02SVT's Avatar
MI02SVT
Yes they can do a load test but sounds to me like your starter solenoid is sticking while your there pick one up I think they're fairly cheap and takes all of 10 mins to replace while you already have the battery off
Old Mar 24, 2016 | 10:12 AM
Conanski's Avatar
Conanski
Sounds more like an ignition switch or solenoid problem than a battery problem.
Old Mar 24, 2016 | 02:29 PM
SoCalAngler
In the event it was the solenoid or ignition switch, can it be bypassed/jumped at the solenoid to start (in an emergency)?
Old Mar 24, 2016 | 02:41 PM
SoCalAngler
also, when you mention solenoid....are you referring to the starter relay or starter solenoid? The relay is small part on the firewall, correct?
Old Mar 24, 2016 | 03:44 PM
warren561's Avatar
warren561
Put a voltmeter on the battery terminals and have a friend try to start the truck.
A good battery should read about 12.5 V or more with no key in ignition and no lights on.
While cranking, the voltage should not drop below 12.2 V.
Old Mar 30, 2016 | 08:09 AM
SoCalAngler
Replaced the starter relay (on firewall) and all is good! The relay was the problem. Battery is fine.
Thanks for the help!
Old Mar 30, 2016 | 01:21 PM
MI02SVT's Avatar
MI02SVT
Solenoid/relay meh glad you got it fixed
'70 ford f250
Mar 18, 2013 09:20 AM
nateraz1
Oct 8, 2011 06:08 PM
vegatyme
Jun 25, 2008 11:14 AM
podman152
Nov 29, 2004 06:57 AM
tealboy1
Oct 10, 2004 06:42 PM
