Bad knock
Old Mar 23, 2016 | 07:08 PM
tjustice's Avatar
tjustice
Bad knock
So was sitting at an idle in park and truck starts knocking, horrific sound. So shut checked oil, good, went to work came out 8 hours later, started up still knocked. Pulled into drive hit the pedal, knock went away, stopped at red light, knock came back......Truck has been parked for 3 days, still knocks at an idle but soon as tap the pedal and give fuel it goes away... Tried unplugging injectors one at a time to eliminate, still had knock. any suggestions???????
Sorry forgot the details::::: 2003 auto, 4wd, studded,deleted, coolant filter, sct with innovative tunes 108,000 miles.
Old Mar 23, 2016 | 07:19 PM
KDAVID1's Avatar
KDAVID1
Bad rocker, lifter, or both?
Old Mar 23, 2016 | 07:39 PM
tjustice's Avatar
tjustice
Hope that simple, but based on the loudness going with neither.... What gets me is, as soon as accelerate it is gone, truck runs fine
Old Mar 23, 2016 | 07:56 PM
speaser's Avatar
speaser
is it smoking and stinking smoke? if so injector could be stuck open, unplugging wont matter because it is mechanically stuck open. if it was a lifter or valve train component it would miss. as soon as u give it fuel the rpm goes up and uses the fuel instead of "flooding" it , of sorts. usually it will smoke like hell and smell raw fuel out tail pipe. the good thing is if u replace failing injector it usually causes no damage, if it was a 6.4l the engine would be junk. hope this helps.
Old Mar 23, 2016 | 09:28 PM
tjustice's Avatar
tjustice
Sad part is the injectors are all new, well new Re-mans....less than 500 miles and 2 weeks on them.. Next question, how to determine which injector. Rockers and lifters and such have no obvious issues, just looking at moving and such
Old Mar 23, 2016 | 09:29 PM
tjustice's Avatar
tjustice
yeah, smelled really rich, burn your eyes type rich....blueish upon throttle smoke but not bad
Old Mar 24, 2016 | 09:06 AM
KDAVID1's Avatar
KDAVID1
Injector issue them
Old Mar 24, 2016 | 05:18 PM
tjustice's Avatar
tjustice
Well swapped out all 8 injectors still have the knock.... what now?????
Old Mar 24, 2016 | 07:35 PM
78fordman's Avatar
78fordman
Any codes set? If it goes away when put in drive, I would make sure the trans to engine bolts are tight and do a visual on the flex plate to torque converter studs.
Old Mar 24, 2016 | 08:54 PM
tjustice's Avatar
tjustice
No codes..... Will head under her in the morning...
Old Mar 25, 2016 | 12:45 PM
NotURMailman's Avatar
NotURMailman
That's what I was thinking.
Loose flex plate bolts or cracked flex plate?
Easy to check...
Old Mar 25, 2016 | 02:39 PM
BLADE35's Avatar
BLADE35
Did they trade them injectors in for you
Old Mar 25, 2016 | 03:09 PM
Per4mance's Avatar
Per4mance
And are they Ford reman's?
rockster
May 31, 2013 11:00 PM
bigpowerstroke
18
Jan 12, 2012 02:48 PM
DIYMechanic
Sep 24, 2011 06:44 AM
lifted_01_SD
22
Jun 25, 2006 07:11 AM
