.help
Old Mar 21, 2016 | 12:48 PM
Tristan Shaner's Avatar
Tristan Shaner
.help
.hello please help me I'm having some problems with my Ford Ranger XLT its a 2000 I just recently went through a fuel pump replacement and after replacing the fuel pump proceeded to try and start it and once the fuel was pumped up to the fuel rail all it would do was start bearly start to run and then die can you please helpcan figure out what it fi
Old Mar 21, 2016 | 06:13 PM
Kruse's Avatar
Kruse
Do you have any idea how hard it is for somebody to troubleshoot your truck with only the details you have listed?
Okay, how about a few more details? Exactly why did you replace the pump? Did YOU replace the pump or somebody else? What brand of replacement did you use? Are there any codes present? How much fuel pressure do you have on the rail? Did you replace the fuel filter?
Old Mar 22, 2016 | 08:20 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
I know your frustrated that the repair hasn't gone as expected, but as Kruse has said, it would be helpful to provide the info he has suggested, as it could help focus & shorten your trouble shoot.
All that said, with the clues you've supplied about it wanting to start & run, but doing so poorly, puts fuel pressure & delivery rate high up on your suspect list. Without more clues, I agree at this point the fuel filter would be a good suspect, maybe along with a crimped/restricted fuel line, or maybe under load voltage drop to the fuel pump. So a fuel pressure & volume delivery rate over time test is in order as he has suggested. Fuel pressure at the fuel rail Schrader valve test port should be 64 +/- 8 psi & delivery rate should be 1pt/15 seconds. I also like the computer scan for trouble codes idea, as you could have more than one problem, so let us know what you find.
firemarshalmike
31
Jan 19, 2014 09:25 PM
polkswampkennel
Aug 31, 2011 09:35 PM
DJdemon6696
27
Dec 2, 2007 04:43 PM
kmerk
Jun 25, 2007 11:51 AM
bjohndev6789
Aug 9, 2005 08:28 PM
