Sponsored by: Real Truck
Fuel Problems
Old Aug 31, 2011 | 01:51 PM
polkswampkennel's Avatar
polkswampkennel
Fuel Problems
2003 F250 5.4 triton, have replaced fuel pump, fuel pressure regulator, and fuel filter, when truck is switched on the fuel pump kicks on and will not stop running. Truck will turn over, but not start. I know fuel pump should only run for 2 or 3 seconds and stop, but will not stop. Any ideas on the problem and a solution to fix would be very much appreciated.
Old Aug 31, 2011 | 01:56 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello polkswampkennel and welcome to FTE.
What is the fuel pressure at the fuel rail?
Old Aug 31, 2011 | 02:54 PM
polkswampkennel
Have not checked pressure as of yet, but it sprays pretty good when the needle is pushed in, waiting on buddy to get here with tester. Over past 3 weeks it got where it would not start just random times, so I figured weak pump changed it and filter and pump would steady run, so changed the pressure regulator and same thing. Just wondering if I could try anything until the pressure tester got here.
Old Aug 31, 2011 | 04:41 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Any codes?
Old Aug 31, 2011 | 09:35 PM
jh818's Avatar
jh818
Maybe fuel pump relay? Not sure where you would find it, though.
Shawn Paris
Aug 2, 2016 10:56 PM
Tristan Shaner
1983 - 2012 Ranger & B-Series
Mar 22, 2016 08:20 AM
matt2fan
Jul 10, 2012 03:13 PM
MrJames159
Nov 11, 2010 08:15 PM
DJdemon6696
27
Dec 2, 2007 04:43 PM
