Front hub removal Help
Old Mar 20, 2016 | 11:40 PM
Seanosu's Avatar
Seanosu
That's the same nut and lock that's on mine. Looks like I need to change nuts.
Old Mar 20, 2016 | 11:41 PM
kmjone00's Avatar
kmjone00
One more little detail worth noting is to check around for prices on the sockets. I found over a $20 difference for the same socket at different parts stores.
Old Mar 26, 2016 | 01:53 PM
r59's Avatar
r59
Just frustrating I have been at this for 2 weeks and can't get this locknut off this truck. bought 3 sockets none fit. Don't know how to solve this, and I guess no one knows around here just incredible and frustrating
Old Mar 26, 2016 | 04:27 PM
Seanosu's Avatar
Seanosu
Can you post a pic of the inside of the hub ?
Old Mar 26, 2016 | 06:29 PM
BradSmith-7.3L's Avatar
BradSmith-7.3L
My truck had factory auto hubs that's had been changed to Manuel hubs. The lock wasn't changed over on mine either.
BradSmith-7.3L
My truck had factory auto hubs that's had been changed to Manuel hubs. The lock nut wasn't changed over on mine either. Once I got the right size hubs, I had to replace the lock nuts or the hubs wouldn't had fit on enough to get the snap ring on. I had to order the 350 parts to fit on my 250. Go figure...
Old Mar 26, 2016 | 11:52 PM
r59's Avatar
r59
I had to take the truck to a repair garage to get the F#ing hubs off. I hate to do that but had no choice.
My hubs are manual and have always been manual. I find it weird nobody in Phoenix knows the correct locknut wrench for this truck. They all look at you like it's a part for a spaceship or something. Ford didn't even know WOW!
All that just to replace rotors. So I bought 5 wrenches total from autozone,Oreilly's. Napa and none where right and none had a set for loan or rent, just crazy!
Nothing weird about the truck, standard Dana 60 4x4 hub as shown here http://www.thedieselstop.com/faq/949...e=stjs53cr.htm for the manual locking hub.
Tool # D85T-1197-A is another mystery.... Crazy just crazy...sorry guys rant over
Thanks to all the fine forum members for their help with this many,many Thanks!
RR
Old Jun 11, 2016 | 04:34 PM
Bluestreakrem's Avatar
Bluestreakrem
Glad I found you guys.
This is my first brake job on this truck at 80K miles. I need to get my rotors off so I can have them turned because one of the pads just got into the rotor before I noticed there was no pad remaining.
Got recommendations on replacement pads?
I need to remove the inner nut in the hubs.
I have a 1997 F350 4x4, OEM straight axle with auto locking hubs.
How do I find out what axe I have?
Is it a Dana 60?
Can anyone confirm the hex socket wrench size and where I can get it?
I plan to rework the calipers, pulling the pistons and replacing the seals and dust boots. I will also replace the hoses. All I can find are hoses from Skyjacker. My truck has a reverse spring shackle kit on the front so the effective lift is about 3-4 inches above OEM.
Where can I find braided stainless hoses a little longer than OEM?
Thanks Guys!
Old Jun 11, 2016 | 05:30 PM
z31freakify's Avatar
z31freakify
Welcome to FTE.
Might want to start a new thread so there can be more responses.
Old Jun 12, 2016 | 09:20 AM
Bluestreakrem
Will do.
Thanks
Old Aug 2, 2016 | 12:20 PM
Bluestreakrem
Yukon seems to make very strong all chromemoly 4140 hubs if you want manual locking hubs.
Will cost about $ 500.00 for a complete conversion.
https://www.ringpinion.com/b2c/Produ...x?ProdID=11867
Old Sep 21, 2024 | 09:48 PM
samuel4wolfpack's Avatar
samuel4wolfpack
I have the dana 50 on my 1996 F250 4x4 HD with manual hubs. I have seen some reviews that this PowerBuilt 648477 socket apparently works for the spindle nut.
Amazon.com: Powerbuilt Spindle Nut Socket, Removal Spindle Nuts, 4-Lug, Dodge, Chevy, Ford, GM Trucks, Hub Sockets, Truck Repair Tool - 648477 : Automotive Amazon.com: Powerbuilt Spindle Nut Socket, Removal Spindle Nuts, 4-Lug, Dodge, Chevy, Ford, GM Trucks, Hub Sockets, Truck Repair Tool - 648477 : Automotive
USERX
May 4, 2019 05:41 PM
jcammarata
Feb 16, 2014 06:40 AM
tommyz270
May 16, 2005 03:18 PM
rcassara
1978 - 1996 Big Bronco
Oct 11, 2004 09:26 AM
89Bronco_EddieBauer
Aug 1, 2003 03:08 PM
