1985 F-150 Starter Problems
Old Aug 12, 2003 | 08:56 AM
jaydlyn506's Avatar
jaydlyn506
Question 1985 F-150 Starter Problems
My grandpa has a 1985 F-150 that keeps eating up starters. He said the motor is a 251 Windsor. I think the motor was rebuilt at one time but I'm not sure. Anyway, we replaced the flywheel and anything else we can think of and it still does it. It is just going through them. Any ideas from anyone would be great. thanks
Old Aug 12, 2003 | 09:29 AM
zigzagn's Avatar
zigzagn
Might need to shim the starter to get a better match between the flywheel and the starter gear. Is it chewing up the gear or killing the starter electrically?
Old Aug 13, 2003 | 08:29 AM
jaydlyn506's Avatar
jaydlyn506
I am not for sure if it is doing one or the other. I know when I had it nd the starter went out on it, it would make a grinding sound until it finally started and then it would just eventually grind and not start. I am assuming it is chewing up the gears. It took about a month before it finally quit completely and it has done the same thing to all the other starters we have put in it.
Old Aug 13, 2003 | 09:34 AM
nzabka's Avatar
nzabka
From what I understand, you dont shim a starter for a Ford. Or at least for that motor, I'm guessing you have a 351w, not a 251w.
The only thing that comes to mind is:
Did you get the correct flywheel? The 351w takes a 164 tooth with a 28oz. weight. I'd double check that. Also, make sure you put the flywheel on the right way as far as which direction the weight is facing. I think it should face inwards, from what I remember doing mine. Am I right on that guys?
Old Aug 13, 2003 | 10:06 AM
jaydlyn506's Avatar
jaydlyn506
I will check on that. thanks guys I will let you know.
Old Jul 7, 2004 | 12:32 PM
John Luther's Avatar
John Luther
Shim???? Do they make Ford starter shims?
Old May 4, 2015 | 04:01 PM
Itsjustin05's Avatar
Itsjustin05
Help
I'm having the same problem.
I have a 1985 f-150 with a 351W and every time I start it it's grinding I just replaced the starter and it's still making the noise. I need help! Please
Old May 4, 2015 | 04:07 PM
InfantryCPT's Avatar
InfantryCPT
manual or automatic? we just did a big thread on them about 2 weeks ago
Old May 4, 2015 | 04:15 PM
Itsjustin05
It's an automatic, 2WD can you send me the link to thread I'd appreciate it thanks!
Old May 4, 2015 | 04:19 PM
Itsjustin05
Automatic 2wd can you send me the link I need to figure this problem out soon. Thanks!
Kingcobra1
Engine Swaps
May 9, 2017 10:00 PM
Dublought
Mar 27, 2016 07:21 AM
AtlM5
Dec 13, 2015 07:57 PM
1985tullyhowell
62
Feb 11, 2014 02:18 PM
redstone
May 20, 2001 07:22 PM
