Repairing window regulator
Old Mar 19, 2016 | 10:58 AM
farmall_7's Avatar
farmall_7
Both window regulators in the 51 have the stub for the window crank handle sheared off. Other than that they are in fine shape. I hate to purchase a whole unit due to that one issue. I have not been able to locate a repair for this, only the complete units. Have any of you taken a shot at such a repair, and if so could you share the details and/or successes/failures of such an endeavor?
Old Mar 19, 2016 | 12:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did the handle fail, or the shaft in the regulator?
Old Mar 19, 2016 | 12:42 PM
farmall_7's Avatar
farmall_7
the shaft in the regulator sheared. What remains is left in the handle.
Old Mar 19, 2016 | 01:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd have sworn someone was selling just the shaft with pinion gear, but I'm not seeing it for 48-52's.
Someone must have been seriously abusing that for it to fail like that. Can you tell if the rest of the regulator is in decent shape?
Old Mar 19, 2016 | 01:25 PM
farmall_7's Avatar
farmall_7
the regulator itself is good. moves relatively freely, surface rust only. I also have been looking for just the gear, but with no success. I suppose I could locate a used, reasonable priced one and swap the gears.
Old Feb 9, 2017 | 04:45 PM
red3644's Avatar
red3644
I'm in the same situation. The shafts are actually like pot metal or zinc. My passenger
side just crumbled while the rest of the regulator is good. I see repair kits for other apps
but not for '51 trucks.
cookieman69
Apr 22, 2011 07:17 AM
rangerboy971
1983 - 2012 Ranger & B-Series
Jan 16, 2010 06:10 PM
Holmsey
Mar 29, 2009 12:53 PM
hotroddoc
Jun 3, 2006 09:24 PM
87liftRanger
Dec 24, 2003 07:05 PM
