I just had my interior redone. The new door panels are too thick to put the window crank handle back on. I ordered a longer window regulator repair shaft from Sacramento Ford.
How does one remove the old shaft and put in the new shaft?????
Take the screws out of the door to take to entire regulator handle off, then drill the rivet out place the new one in and rivet it back on and replace.
Jaye
