Dash Indicator Lights Out
Old Mar 18, 2016 | 08:00 PM
btkelk's Avatar
btkelk
I'm new to the site and could use some help with this: The right side dash indicator lights on my 90 F150 5.0L 4WD XLT Lariat are all out, but the turn signal/flashers and 4WD work fine. It was like this when I got the truck. I checked all the fuses and removed the instrument cluster and replaced all the bulbs and they're still out. The underdash wiring looks clean and the instrument cluster did not appear to have ever been removed. Could this be a bad connection or ground? Thanks for any advice.
Old Mar 18, 2016 | 11:46 PM
Lead Head's Avatar
Lead Head
I believe most of those lights are normally applied + power when the ignition is switched on, and they're grounded to turn them on. I'd start by checking to see if the bulbs have +12v on one side of them with the key on.
Old Mar 19, 2016 | 12:49 AM
timbersteel's Avatar
timbersteel
Short in the headlight switch maybe?
Old Mar 19, 2016 | 07:46 AM
subford's Avatar
subford
You may have an open in the headlight switch. The bulbs are always grounded and power is supplied by the headlight switch and not the ignition.
Fuse #4 or #10 may also be open.
Also turn the headlight **** to see if they come on.
Old Mar 19, 2016 | 08:09 AM
Lead Head's Avatar
Lead Head
Subford, I think he's talking about actual indicators, like check engine, etc..., not dashboard illumination?
Old Mar 19, 2016 | 08:40 AM
subford's Avatar
subford
But he said that he replaced all the bulbs and that the 4X4 lamp works.
The 4X4 lamp gets its power from the smae place as the check engine.
Old Mar 19, 2016 | 11:14 AM
timbersteel
The same thing with my headlight **** is starting. If I don't pull it out fully and then twist to the right, my dash lights won't come on but my headlights will.
Old Mar 19, 2016 | 11:25 AM
btkelk's Avatar
btkelk
The actual indicators are out, not the instrument panel illumination. All 4 bulbs on the right side are out: anti-lock indicator, 4X4 indicator, 4X4 Low Range indicator, and RH Turn indicator. They just don't come on. The brakes work fine, the 4WD is engaging in both high and low range, and the RH turn signal exterior lamps work too. All the indicators on the left side of the dash, check engine, LH Turn signal, etc, work fine. The cluster diagram shows separate wiring to the left side and right side indicators from the fuse block, so that may explain why only the right side could be out. I noticed the previous owner did do some wiring under the dash, tapping the fuse block, and could have screwed something up. Real PITA.
Old Mar 19, 2016 | 11:41 AM
subford's Avatar
subford
So no power to C250 pin #13.
A red wire with a yellow stripe, wire #640.
Old Mar 19, 2016 | 09:58 PM
btkelk's Avatar
btkelk
Well, that narrows it down. Thanks, Subford.
78 & 87 Super Cab
19
Mar 31, 2026 09:52 PM
shameless
Sep 9, 2016 02:21 PM
lawdogg_78
Sep 8, 2012 08:03 AM
joe f350
Jul 1, 2010 08:42 PM
1978fordf250
20
Sep 3, 2008 09:47 PM
