I had work done on my 6.0 liter Super Duty a little while back and now I have a no start issue found Top O ring to be blown out as well as retainer clip and the beveled washer broken in 3 places can the washer be replaced or do you have to buy a whole new injector
At this point I would say that it's less risk to replace it. If when it cracked small
fragments scored the spool valve in the process I feel that it's not worth the risk.
The beveled spaces looks to be made from sintered steel. Not what you want floating
in the intake to the spool valve.
