Sponsored by: Real Truck
Ignition Switch and Easy Entry/Exit Question
Old Mar 16, 2016 | 01:25 PM
Po6ept's Avatar
Po6ept
My 2013 F-250 diesel came with the easy entry/exit feature. For the first 2 1/2 years, the seats moved forward as soon as I inserted the key. Now they are intermittent. When I insert the key without turning it, the seats will sometimes move and sometimes not. If I touch or jiggle the key a bit, the seats move forward and back and the indicator lamps on the top gauge row flash.
My dealer says this is normal behavior. They even showed me another truck on the lot that does the same thing. What confuses me is that mine did not behave this way before.
Does anyone else have this problem? How does it behave in your truck?
Thanks,
Bob
Old Mar 16, 2016 | 01:35 PM
senix's Avatar
senix
Mine works just like yours did for the first two and half years.
Mine is also a 2013.
Can you verify your settings in the settings menu?
Old Mar 16, 2016 | 01:51 PM
Po6ept's Avatar
Po6ept
The settings are correct and I can turn the feature on and off but it behaves as though the ignition switch is flaky. What happens if you insert your key and then move it slightly forward and back? (Not turning it, just gently moving the head of the key towards the dash and the rear.)
Old Mar 16, 2016 | 02:10 PM
senix's Avatar
senix
I will try that this afternoon after work. Let you know.
Old Mar 16, 2016 | 03:05 PM
senix's Avatar
senix
Mine does not do what you are describing. Jiggleing the key does nothing to the seats or gauges or lights.
Matter of fact there is virtually no play in the key mechanism.
I'd say yours is worn out and needs replaced.
NewEnglander
1978 - 1996 Big Bronco
17
Apr 16, 2012 11:46 PM
f350xlt460
Nov 28, 2005 01:59 PM
valvestud
Jan 3, 2005 12:48 PM
johnlynn
Dec 27, 2003 10:17 PM
1986f_150
Feb 25, 2000 10:42 PM
