Sponsored by: Real Truck
Key stuck in ignition switch
Old Jan 2, 2005 | 11:22 AM
valvestud's Avatar
valvestud
Hi all,
My 2001 (Excursion) has eaten my key and won't give it back. The switch operates normally otherwise. I've already removed the switch assembly, but can't see any way to repair or at least remove the key. Since I'm traveling and won't be back home until late tonight, I don't want to mess with it.
Assuming I buy a new assembly, what's the procedure to key it alike to the doors? Does the new assrmbly come with new keys or does the Dealer have to set to my key?
I have keyless entry, so it's not a big deal, but I don't like not being able to open doors with key if the keyless fails.
Thanks,
Joe
Old Jan 2, 2005 | 11:46 AM
Rongold's Avatar
Rongold
Talking Lock Cylinder
Most new ignition lock cylinders come already coded with a new pair of keys, but then you have different keys for the doors and ignition. Any competant locksmith cna usually recode the cylinder to use the old existing key. Just make sure that you have a "GOOD" original key--they WILL NOT be able to make an old worn out key work properly.
*** RON ***
Old Jan 3, 2005 | 12:48 PM
valvestud's Avatar
valvestud
Thanks for the reply Ron.
I was able to get it temporarily repaired a local locksmtih. One of the tumblers is damaged and was removed.
FYI, Ford dealer wants $80 for a new unit, which then has to be keyed to my key by a locksmith.
The locksmith can order lock and key it to existing keys for less than $50.
Joe
