So I did a quick re-ring on this 390 I acquired for my 77.
Got it in and fired up, #5 cylinder is not firing. I have spark all the way to the plug. Checked with a vacuum gauge and it jumps wildly at idle, the needle is sweeping back and forth about half the gauge. At about 2200 or 2300 it smooths out but then I can't tell if it's still missing. Figured it was an internal leak around the manifold so I took it off and re sealed it. started up, exactly the same. I also lapped the valves when I had it apart and the heads were off and checked for a seal with soapy water and compressed air so I don't think it's a burned valve. I started it with the valve covers off and it looks like the lifters and push rods are working fine, I've got all new lifters, springs and hardware. When I re-sealed the manifold I checked the push rods and they're not bent.
FWIW the plug is black and sooty.
Any ideas?
Compressions good. 130# to 145# on all the cylinders. I guess I should do a leak down test. I just don't see a leaky valve making it miss that bad.
# 5 cylinder was 135#
Swap the plug and plug wire with another cylinder (making sure you move the wire at the distributor cap too) and see what happens.
How did you determine that #5 wasn't firing?
I know because when you unplug that wire it makes no difference to how it's running. If I unplug the other wires it stubbles and misses. I know it's got spark all the way to the plug because I took the plug out and ran it with the plug grounded. It's got a nice fat spark at the electrode.
