Engine miss
Old Nov 20, 2008 | 09:38 AM
Okiedokie's Avatar
Okiedokie
Engine miss
What am I missing? 84 302 Ford HO motor. Edelbrock intake with 500 cfm Edelbrock carb. HEI distributor. Motor has developed a dead miss on # 5 cylinder. Compression is 120 to 130 in all cylinders. Idle vacuum is 20 inches. Following the chart for vacuum gauge reading, there is no indication of any related problem areas. Once I isolated the cylinder by removing plug wires untill one had no effect, I installed an ingition test device that goes between plug and wire end cap. It was firing strong, so I replaced the plug, no change. Thinking I might have a cam problem I pulled the vc and found that both valves are opening and closing. I am just a hobbiest and have no training in diagnosing this stuff, have I overlooked something? Joe
Old Nov 24, 2008 | 08:50 AM
bashby's Avatar
bashby
A vaccum leak on that intake runner will cause a miss. Spray carb cleaner around the intake and see if it smooths out
Old Nov 24, 2008 | 09:10 AM
Okiedokie's Avatar
Okiedokie
Thanks bashby, you are 100% correct. A local guy suggested I do the same and that proved to be the culprit. I had assumed that a leak there would cause low idle vacuum, but it did not. I do appreciate your input. Joe
