Fuel hose size
Old Mar 14, 2016 | 03:43 PM
ktm4012's Avatar
ktm4012
Fuel hose size
Can someone tell me the fuel hose size that's along the frame on my 79 F 250? I bought 3/8 hose but when attaching it to the steel tubing along the frame it's way too small. I'm sure 1/2 hose would be too big. Is there anything in between? Thanks
Old Mar 14, 2016 | 04:34 PM
kadrocker's Avatar
kadrocker
Last week I replaced the rubber fuel lines on my truck, they were 3/8 of an inch. Fit perfectly on to the steel tubing
I have a 76 F150
Old Mar 14, 2016 | 05:27 PM
84espy's Avatar
84espy
My 75 F250 w/460 uses 3/8 hose. It may be that the hose needs to be warmed to install easier. Try dipping into cup of hot water.
Old Mar 14, 2016 | 06:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
+3. The fuel line from the tank to the pump is 3/8".
Old Mar 14, 2016 | 06:40 PM
ktm4012's Avatar
ktm4012
I just read fuel injection hose is a tighter fit. Didn't know that.
Old Mar 14, 2016 | 08:35 PM
HIO Silver's Avatar
HIO Silver
Yeah... cuz its burst pressure is like 300 PSI or more... whereas a carb's rubber hose only has to anticipate less than 10 PSI under typical applications.
MadAustinite
3.8 & 4.2L V6
Apr 2, 2011 11:05 PM
n3vyk
Mar 17, 2010 02:06 PM
84-250
Oct 17, 2009 02:58 PM
