electric overdrive
Old Mar 8, 2016 | 07:46 PM
three on the tree's Avatar
three on the tree
Question electric overdrive
have 78 F150 351M with C-6 tranny
Looking to put an electric overdrive on the back of the tranny so I get better mpg and engine works less . Anyone have input on this and what overdrive is best for simple and most dependable or better yet as bullet proof as possible?
thank you for the info.
Old Mar 8, 2016 | 08:15 PM
Steven@nd's Avatar
Steven@nd
Gear Vendors... around $3000 for a c-6.
Old Mar 8, 2016 | 09:01 PM
three on the tree
OMG was hoping for half that
Old Mar 8, 2016 | 09:08 PM
raytasch's Avatar
raytasch
Believe Nothing
Once in a while a used one will show up on ebay. Be sure to run a cooler on the tranny if you install OD.
Old Mar 11, 2016 | 12:27 AM
three on the tree
will be putting on a tranny cooler , like to keep the fluids separate, friends old car had 351 and a C-4 , cooling tube for tranny leaked and antifreeze took out tranny.
my 77 F250 with C-6 had two coolers and was great, fluid came back low temp and ready to work lol
Old Mar 11, 2016 | 08:06 AM
jbehuniak's Avatar
jbehuniak
your engine would work less if you swapped out for a overdrive transmission that had a lock-up torque converter. There are threads on the swap and running different type transmission controllers. It doesn't look too hard
Old Mar 11, 2016 | 11:29 AM
beartracks's Avatar
beartracks
I have the Gear Vendors OD and it's great. It's bullet proof, they put the same unit in dump trucks. It's only 22% overdrive though.
As far as a latter model trans I haven't heard of any adapters. If someone does please post.
Old Mar 11, 2016 | 02:27 PM
jbehuniak's Avatar
jbehuniak
351M and 460 share the same bell housing you should be able to E4OD with a trans controller
Old Mar 14, 2016 | 09:51 PM
BLK79's Avatar
BLK79
Not your question, but I put 3.00 gear sets in a 79 Bronco that had 3.50. Hwy cruising is comfortable now. 33" tires also. Rear 9" was easy. Frt 3.00 hard to find. If yours is 2wd not an issue
Tsoptich
Oct 24, 2009 04:51 AM
Cadfael_420
26
May 24, 2006 07:58 PM
