Strange starting issue
Old Mar 14, 2016 | 01:07 PM
Amicus's Avatar
Amicus
Over the past year I have been upgrading my truck with new parts and a few mods. Last thing I did was replace the icp and ipr sensors. Truck has been running great. But recently over the last few days when I turn the key to start all I get is a click. After several try's the truck will start strong. At First I would wiggle the shifter and sometimes it would start after wards. The other day I put in N and it started but Im starting to thing the shifter has nothing to do with it and it was just a coincidence that started. Because sometimes after a few trys it will start with out ever touching the shifter. Now the other day we had a cool morning and I went out to start the truck and let warm up. It started fine but when I turned the defrost on it turned off I mean it just died. Started it again turned on the defrost and it died. It happened a third time. So I started let It warm up and then turned defrost on and it stayed on. You can feel/hear the power drain when the air is turned on. Also felt the power drain when we tried to roll down or up the windows. All this happens only when the vehicle is warming up. This Morning it was doing the same thing so I paid attention to the battery gauge and saw that when I would turn the key nothing would happen it would not read at all. Then when it did start the gauge did not pick up for a few seconds, meaning, it showed zero amps for a few seconds and then slowly pickup to normal about 3/4 up.
I'm thinking its an alternator issue but that's just a guess. Batteries are less than 2yrs old and starter is fairly new as well. I can't remember when I replaced the alternator. Any help would be appreciate it.
My truck is a L99 f350 with 386,000.
Thanks
Gilbert
Old Mar 14, 2016 | 01:43 PM
hydro man 17's Avatar
hydro man 17
Tired batteries come to mind, and/or alternator especially if you running and the extra power load kills the engine, most likely due to low voltage.
Old Mar 14, 2016 | 02:41 PM
AllaboutMPG's Avatar
AllaboutMPG
Look at all your cable connections, especially the grounds on the firewall and engine block.
Old Mar 14, 2016 | 06:28 PM
Amicus's Avatar
Amicus
Thanks, gentlemen
I have checked all the connections and all is clean and tight. Batteries are are about 2 yrs old diehards. I need to check alternator.
Old Mar 14, 2016 | 06:49 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Check the batteries too. Yes, they should last a lot longer than 2 years, but one of them my be bad.
AllaboutMPG
The power drop, intermittent starting, intermittent gauge, etc made me think loose ground. The starter itself could be going out.
An easy way to watch voltage is with one of these
Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive
You can see batt voltage before cranking, with key on, watch for glow plug draw, and see if your alt is putting out the right charge
Old Mar 14, 2016 | 07:05 PM
Amicus's Avatar
Amicus
Alright gentlemen, I'm getting 12 v from batteries. When truck is on I'm getting a little above 15 v. According to the u tube video on how to check alternator, my alternator is overcharging? Is that right? I really appreciate the help.
Old Mar 14, 2016 | 09:59 PM
crop harvester's Avatar
crop harvester
either alternator over charging or volt meter inaccurate.can You borrow another volt meter to confirm.
Old Mar 15, 2016 | 09:41 AM
Amicus's Avatar
Amicus
Oreillys checked alternator they say it passes. Is there any think else that may cause alternator to over charge? I know Oreillys could be wrong. I'm kind of stumped. Any suggestions would be appreciated?
Old Mar 15, 2016 | 01:40 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
What output did they see?
Old Mar 15, 2016 | 03:46 PM
Amicus's Avatar
Amicus
after Oriellys I went to napa they checked and said that it was reading 14.5 volts. Went home and reinstalled alternator and still got a 15.7 reading. Going to picup another meter just to make sure.
Old Mar 16, 2016 | 05:17 PM
Amicus's Avatar
Amicus
Just invade anyone is interested. I bought a new alternator and starter selenoid. After installing the alternator I tried to start and got the same click after a few clicks it started strong. So I start to remove the selenoid and one of the post just spins post and nut. Found my starting problem. With very little effort I was able to twist post off. A bunch of dirt/crude fell out. Replaced with a new selenoid and it's starts like new . Thanks for all the help.
Old Mar 16, 2016 | 06:57 PM
Syncrowave's Avatar
Syncrowave
Glad it worked out. Thanks for the solution report.
OKeefe73
Oct 16, 2017 05:23 PM
sithways
1983 - 2012 Ranger & B-Series
Oct 30, 2016 01:38 PM
BobbyB
Jan 14, 2011 09:19 PM
wickedmax13
Jul 20, 2010 04:27 PM
TearDaClubUp
31
Jun 2, 2005 08:47 AM
