excess fuel
Old Mar 16, 2016 | 12:39 PM
renchr56's Avatar
renchr56
excess fuel
Hello all. I have a 2001 F-350 w/7.3. There was excessive smoke coming from the exhaust. So the first thing I did was to pull the glow plugs to see what they looked like. and while having them out I cranked the engine over. Upon doing so I noticed 1 cylinder putting fuel out of the hole. Meaning it was like you could put your hand about 6 inches above the hole and your hand would be wet from fuel. None of the other cylinders was like that. So what I did was pull the injector from the cylinder next to it and put it in to see if it was the injector failing. But it was still doing the same thing. Any ideas as to what would cause this??
Old Mar 16, 2016 | 11:06 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the problem did not follow the injector but stayed with the hole, I'd look at the wiring to that hole and the IDM.
Old Mar 17, 2016 | 06:46 AM
renchr56's Avatar
renchr56
I forgot to mention I had all electrical disconnected as well when cranking. So it cannot be an electrical issue. Which in turn means that the injectors are in the closed position.
Old Mar 17, 2016 | 07:22 AM
Rikster-7700's Avatar
Rikster-7700
Could it be leaking cups? In this scenario the fuel pressure is higher than the oil pressure and causing it to leak fuel into the cylinder? Have you checked your fuel filter to see if it oily looking? Might be a long shot?
thatonefordguy
Aug 16, 2012 05:59 PM
jlarsen513
Modular V10 (6.8l)
Sep 20, 2011 07:50 PM
loudsoundguy
May 2, 2011 07:50 PM
97F250LD4X
Jun 14, 2010 11:49 PM
nightskyisme
25
Apr 22, 2007 07:37 AM
