Need help
Old Mar 18, 2016 | 09:07 PM
Tigercat870's Avatar
Tigercat870
Originally Posted by CampSpringsJohn
Try turning on your headlights, then try starting. See if the lights go real dim or out. If they go dim, the batteries may be low. If they go out, then you may have a faulty ground somewhere. Have you tried jump starting it?
I took the starter off and tested it. it seems fine.. I put a new starter solenoid on the fender it u cross the two big studs it well only make the starter click . I have new alternator new gpr new starter solenoid.and new batteries 😡
Old Mar 18, 2016 | 09:15 PM
ExPACamper's Avatar
ExPACamper
Your starter gets its ground from the mounting bolts. Are you sure it is on tight?
Did you check the voltage at the solenoid, maybe it is low? It's easier to check than down at the starter.
How did you check the starter when you had it off?
Old Mar 18, 2016 | 09:17 PM
FiznUKa's Avatar
FiznUKa
What year is your truck.
Tigercat870
[QUOTE=ExPACamper;16136024]Your starter gets its ground from the mounting bolts. Are you sure it is on tight?
How did you check the starter when I hooked it up to a battery
Old Mar 18, 2016 | 09:23 PM
CampSpringsJohn's Avatar
CampSpringsJohn
You might try jumpstarting it. Hook positive to positive on the batteries, but hook the negative to the motor.
Old Mar 19, 2016 | 08:23 AM
Walleye Hunter's Avatar
Walleye Hunter
You have thrown a bit of money chasing this problem. A classic case for why one should diagnose and systematically troubleshoot a problem. At this point I would go to your battery connections starting with your grounds. I do not know exactly where those batteries ground so I can't direct you right to them but unbolt them at the block and thoroughly clean them. Check the condition of the wires where they meet the connectors, there could be corrosion and degradation of the wire there. I usually apply grease to such connections when I have them off but others may have opposing thoughts on that act.
Old Mar 19, 2016 | 09:35 AM
Tigercat870
Thanks for all the help boys...I ran a new ground from the battery to the starter and away it went
Old Mar 19, 2016 | 11:17 AM
Walleye Hunter
Glad to hear it but that definitely indicates that you have a ground problem and you should check those battery to block grounds.
Old Mar 19, 2016 | 01:16 PM
ExPACamper's Avatar
ExPACamper
^^^ THIS ^^^
If your ground is bad, it might all be running down that new ground wire now.
Better check out the battery to engine ground and the bolts on the starter.
Old Mar 19, 2016 | 01:32 PM
Tigercat870
Originally Posted by ExPACamper
^^^ THIS ^^^
Yup next step replace all the cables
kt19
Jan 4, 2012 10:15 PM
IHMANKY
Mar 13, 2011 08:43 PM
Quick444
28
Dec 12, 2009 01:47 PM
Raznwlvs
27
Apr 18, 2009 03:50 PM
Rich in CO
Oct 23, 2005 10:02 PM
