400 engine tranny combos
Old Mar 13, 2016 | 08:19 PM
Ford3+'s Avatar
Ford3+
Hey yeall I have a 1978 Ford f250 supercab 4x4 with 400 engine with 3speed auto tranny . would like to swap out tranny for manual, ideally more like a 4 or 5 speed. Was wondering what options I have if any? And what kinda costs I'm looking at ? And how big of a project/pain in butt to do ? Any help I'd be thankful to yeall .
Old Mar 13, 2016 | 09:23 PM
hivoltj's Avatar
hivoltj
4 speed is easy, NP 435 with stock parts, linkage and pedal box. 5 speed would be easiest with a ZF5. Will take some custom fabrication.
Old Mar 14, 2016 | 06:29 AM
Blue and White's Avatar
Blue and White
The NP235 is a great and tough transmission. It is used successfully in MD trucks >20k lbs. 1'st is a non syncro creeper gear to help get rolling with heavy load or trailer. Or for running slow over rough ground. Running light, you would normally start out in 2'nd and it is functionally a 3 speed with pretty wide gear spreads. Some love it, some don't. I had one outlast 2 rebuilt engines and never opened up.
Old Mar 14, 2016 | 11:24 AM
jbehuniak's Avatar
jbehuniak
NP435 is a good trans, they can be found almost everywhere. If you do a lot of highway I would suggest a ZF5. Not the cheapest way to go but it has a lower final drive
Old Mar 14, 2016 | 12:39 PM
Ford3+'s Avatar
Ford3+
Will ether the np435 or zf5 bolt up directly with the set up I have ? I know yeall said needs some fab is needed but is that just meaning the clutch pedal and shifter spot or is that to get the tranny to bolt up as well ?
Old Mar 14, 2016 | 01:46 PM
jbehuniak's Avatar
jbehuniak
The trans will bolt up. You need a flywheel adapter and its a hydraulic clutch
ZF5 adapter kit
I don't have a link but there is a ZF5 swap in the dent forum
Old Mar 14, 2016 | 10:21 PM
phlegm's Avatar
phlegm
Any transmission that will bolt up to a 429 or 460 will bolt up to a 400.
So if you are having trouble finding a 400 trans, try one of the 385 blocks.
Old Mar 14, 2016 | 10:56 PM
Ford3+'s Avatar
Ford3+
So it'll bolt up and will have to get creative with clutch and shifter linkage and all...but what about matching it up to keep 4x4 because autos are usually longer so will I have to change drive shaft and transfer cases and or any of the 4x4 linkages ?
Old Mar 15, 2016 | 06:41 AM
jbehuniak's Avatar
jbehuniak
You may be within an inch, the NP435 and T18 have a spacer between the trans and transfer case. The ZF5 is pretty much that length. The NP205 supposedly bolts right up with a small amount of grinding
Leef250
May 3, 2017 08:47 PM
PrarieOyster
Jan 17, 2006 05:04 PM
Scott_McGee16
Mar 13, 2004 06:55 PM
BroncoRoadKill
Dec 10, 2003 09:25 AM
Racerdave
Apr 23, 2003 01:40 AM
