NEED ENGINE SPECS
1. Where do i get parts for it?
2. Whats the horsepower/torque numbers
3. What other (better) engine could I swap out with it easily?
Any side notes :
1. it has a 16ft dump bed
2. 5 speed manual dual range transmission
Any help would be greatly apprecaited! Thank you!
Worth it?
https://www.ford-trucks.com/forums/5...cs-needed.html
Viewing a thread - Ford truck.........370 engine
I'm pretty sure the crank snout and maybe the rear flange are different. Accessory drives are different, engine mounts may be different.
It's been done, but it's not a direct swap.
Ford medium duty motor swap...429 to 460 | The H.A.M.B.
https://www.ford-trucks.com/forums/8...-460-swap.html
As for parts, NAPA has a lot, you just have to find someone who knows what a medium truck is.
Your transmission is not dual range. You have a two speed rear axle.
Read all about it. It DOES NOT and SHOULD NOT be shifted like a transmission, especially on a down hill.
Post 5 has the Eaton links:
https://www.ford-trucks.com/forums/1...ml#post9565523
