CCV Mod, undone
Old Apr 10, 2019 | 01:09 PM
jimjokjv's Avatar
jimjokjv
I have the BD Diesel set up on there now. From what I can tell they have removed the original breather box (dog house?) and installed one for this kit. The bolts have definitely been over tightened and set in deep enough I could barely get a socket on them.
Would I need to find a factory box to put back on there?
Not sure where the 90 degree hose comes into play either?
Old Apr 10, 2019 | 01:56 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
All you need is for the vent off the dog house to face the front of the truck, then the hose goes from the dog house to the port on the intake.
The o-rings are needed because they are deformed when the dog house is installed.
Old Apr 10, 2019 | 02:32 PM
BWST's Avatar
BWST
Got Data?
Is this bad boy missing from your rig, Jim?
Old Apr 10, 2019 | 03:34 PM
jimjokjv's Avatar
jimjokjv
I will need to look in the spare parts box that came with the truck. Previous owner was pretty good about keeping the stock parts he was replacing.
So after seeing the 90 degree hose I have an idea why the oil consumption is reduced with the stock configuration. Maybe I'm all wet here but it would seem that the vertical path of the hose would cause any droplets to remain in the valve cover whereas in the collection set up it runs down into the catch can.
Ken_C
Mar 16, 2013 06:25 PM
Bvill01
Jul 11, 2012 07:47 AM
caleb90
Jun 21, 2009 11:32 PM
jetdoc
Aug 13, 2006 09:12 PM
SSGG
18
May 31, 2006 09:47 PM
