Hydraulic hose pressure
This is an odd one, but I'll bet someone or a few of you might know. Blew a hose on an older front end loader, Trojan 164. Anyways trying to determine what capacity psi hose I should get. The weight is between 5 and 6 tons, so will lift at least that much. I was told that actual weight being lifted does not necessarily correspond to internal pressure in the line, but it certainly is significant .... the light duty hoses in 3/4 hose size are around 2200 psi, found one rated at 5000 psi, wondered what folks more knowledgeable about this than I think about this ?
Rephrase not what the pump can supply but what the valve body allows
No the weight being lifted doesn't matter it's what the pump can supply 5000 psi hose is more than enough I would guess 3200 would be fine usually what I've gotten made up if you have any heavy equipment shops near you they should be able to make the hose for you
Anyways I asked for an over the phone quote and got a $ 90 estimate, I really should replace 3 lines and I can find not exact sizes but perhaps close already made on Ebay for 20 plus shipping. Oh, apparently there are JIC connectors and a number like 9, 15 whatever, do you know what different numbered JIC connectors mean ?
You can also buy balk hose and replaceable ends. I worked out of a service van on material handling equipment and made replacement hoses on the spot. Only special tool needed was a cutoff wheel on a die grinder to get a clean cut on the braid in the hose. The other advantage is that the ends don't go bad and just the hose can be replaced. Here is a JIC size chart to help understand the sizing.
https://www.surpluscenter.com/images/techhelp/JIC.pdf
on
There should be a place near you that can make the exact hose(s) you need. They cut the hose to the correct length and crimp the correct ends on them.
Around here the auto parts places do this. So do farm implement dealers. Ask around, there is certainly a place near you somewhere.
Received 3,108 Likes
on
Thanks guys. So, for a standard Ford or Case backhoe loader these lines are say 2 to 3000 psi standards ?
90 bucks sounds about right for a hose I would stay away from eBay hoses for that cheap something can't be right
Never knew Napa made hoses that's good to know I usually went to a Parker store near my work or if it was a oddball fitting ais construction equipment which was a John Deere dealer
Wag53 - Very good suggestion, I think I do have the screw type, I will take a pic when camera is done charging .... I might luck out on this if this is the case and then will have to purchase the correct size and capacity hose..
