1972 F100 Blinker Problem
Old Mar 9, 2016 | 08:57 AM
ovaknike1's Avatar
ovaknike1
Exclamation 1972 F100 Blinker Problem
I have a 1972 F100 which i just recently replaced all my lights to LEDs, as well as my flasher relays. Everything Works Perfectly, Except (And Yes, There's always an except) my Right Blinker when i turn it on doesn't flash or stay solid or anything, If i'm lucky It will flash once. My Hazards work and my running lights work, it's just the blinker in the right side rear and front.
Here is a video:
Thanks in advance.
-Kevin
Old Mar 9, 2016 | 09:04 AM
HIO Silver's Avatar
HIO Silver
Kevin,
Avoid starting a new thread on the same issue because doing so results in a lack of troubleshooting continuity....
ORIGINAL THREAD LINKED BELOW!!!!
https://www.ford-trucks.com/forums/1...r-problem.html
Old Mar 9, 2016 | 09:12 AM
Absolute's Avatar
Absolute
Maybe the hazards use a different ground and the ground on that side is poor. Just guessing. My hazards are a different flasher unit so it is its own circuit and wouldn't apply. If that's the case, it could still be a ground, or maybe a bad flasher? It could be the switch too. Easy to test that buy just bypassing it to check if the flasher and circuit is ok. Id check the flasher ground first, then start bypassing switch to test that. Another way is reversing the outputs on the switch, then if it works, it pretty much tells you the signal switch is toast. Since it does light up but not flash, I'm guess the ground for the flasher is bad. That said. LED's can be a pain. Some work, some don't. For how reliable they are said to be, I have had nothing but problems with them, and never use them any more. I replaced all the lights on my 40ft fifth wheel hoping to save battery. Boy did I ever save power. Because the led's burned out about every three days, so they never worked. LOL. Spent hrs checking circuits to see why, and never found an issue or a reason. They just don't work on that thing. Regular bulbs last forever. I have found there are cheap led's, and pricey good ones. They look the same, but its the brain inside that makes them work that's the difference. The cheap ones burn out fast, the expensive ones last as advertised. My 2 cents. LOL.
Old Mar 9, 2016 | 09:39 AM
ovaknike1's Avatar
ovaknike1
How Would i Go About Bypassing the Switch? Also, I have 2 different Flashers, One for Hazards and one for Blinkers. It's Just so strange that only one side is faulty.
Old Mar 9, 2016 | 09:46 AM
gangstakr's Avatar
gangstakr
Don't bypass anything yet, It definitely looks like a ground issue. Your video did not show the rear signals. What are the rear signals doing?
The problem with bypassing is, the problem is still there. You need to correct this problem.
Old Mar 9, 2016 | 09:48 AM
ovaknike1's Avatar
ovaknike1
The rears do exactly what the fronts do. From my understanding there is a ground in the front left and the rear right. The connections look good.
Old Mar 9, 2016 | 09:53 AM
HIO Silver's Avatar
HIO Silver
Absolute's Avatar
Absolute
You would supply 12v to the flasher post that has the switch feed. Wont hurt the switch if its in the neutral position, but if the signal starts flashing with the jump then it tells you the feed from the switch for that side is pooched. If no difference the feed is probably ok, then you bypass the flasher to that side. If it will flash with you supplying 12v, on and off like you are the flasher, then it points to a malfunctioning flasher. I use a button switch on my jumper wire so there is no arcing pretending to be the relay. LOL. So if the flasher is the culprit it could just be the ground, or the flasher. I followed the drawing and its grounded in several places, and combined with other grounds with several grounds reduced down to one in a few places. So any of those joints could be a bad ground, and could cause the resistance making the flasher not function on that side. Its complicated, but if you start at the switch, or bulb, and test each component and wire all the way to the other end. You will eventually find the issue. Sounds stupid, but if you jump around on the circuit you will take for ever to find it. Start at one end and work you way to the other without skipping a piece, you will be isolating each part and will run into the issue. You now have a diagram from the other thread, so get the test light and continuity tester (multimetre), and start tracing and ohm testing grounds and wires. Note: when ohm testing grounds, put the ground lead on the battery ground, not the frame or motor. Also, isolate and ohm test every wire along the way. A test light will still light even though a + wire has resistance, so by ohm testing it will tell you if the wire is 100% or leaking,(grounding out) and if there is any corrosion not visible outside that is causing resistance. A lot of guys don't ohm test, they think it doesn't tell anything if the test light works. The test light will light with as little as 1 volt. Although that would be noticeable because it would be dim, a small leak will not be noticeable.
Old Mar 9, 2016 | 10:04 AM
Absolute's Avatar
Absolute
[QUOTE=gangstakr;16111228]Don't bypass anything yet, It definitely looks like a ground issue. Your video did not show the rear signals. What are the rear signals doing?
The problem with bypassing is, the problem is still there. You need to correct this problem.[/QUOTE
Hahaha. That's funny. No , bypassing is the way you test components to FIND your issue if you don't own the multimetre you need to test properly. My writing may be bad, but I didn't mean bypass to make it work as a permanent solution. I meant for a testing procedure. If you have tools, unplug and test. Sorry for the confusion.
Old Mar 9, 2016 | 10:17 AM
Tedster9's Avatar
Tedster9
Looks got nothin' to do with it. Replace all the old, corroded or missing worn out cables, grind down to bright shiny metal at block, frame, and firewall and tighten securely.
Chess67
13
Jun 28, 2018 11:29 AM
ovaknike1
Mar 9, 2016 09:10 AM
Adam Woolridge
Dec 7, 2015 04:31 AM
DBROWN76
Dec 1, 2010 10:31 PM
DCRB
Aerostar
Aug 19, 2008 06:29 PM
