Overtorque error
Old Mar 9, 2016 | 08:19 AM
nlareau's Avatar
nlareau
Overtorque error
I did something stupid. Again. I amaze myself sometimes.
2007 Ford 4.6L (Crown Vic) motor. Putting it into a 77 F100. Took it apart to check the timing chains and look at valve wear. It was darn near flawless at 170k miles.
Putting it back together, I over torqued the head bolts. Way-way over torqued (like 3x). Don’t ask, I'm embarrassed enough to have to admit it.. Found out what I’d done and have undone it. Time to start over.
Question: I know I need new bolts; do I need to replace the gaskets? They are those multi-layer steel permatorque things. I know the conservative answer is ‘yes’ but I’m pissed off I just wasted $50 on bolts and $45 on gaskets.
Would you think the gaskets were OK? I can’t imagine them compressing – they are steel.
Old Mar 9, 2016 | 12:57 PM
davester250's Avatar
davester250
Were the gaskets just a completely flat sheet of steel before you installed them?
Normally, they would have at least small indentations around important features such as the cylinders, water jacket and oil return passages. And these indentations get flattened a little when you torque the head down.
I'm pretty sure you should get a new set.
$45 now or $45 + a bunch more time later when you have low compression or oil/water leak...
Old Mar 10, 2016 | 09:00 AM
JWA's Avatar
JWA
Get over being pissed at yourself for making the same sort of mistakes all of us here have made---at least those of us being honest!
Like already said spend the money for new gaskets or be prepared to be pissed all over again when you're re-doing this for the THIRD time.
hulaman
Nov 6, 2015 07:48 PM
Early 1969
Jun 3, 2015 04:42 PM
john fin
Sep 10, 2008 08:18 PM
007bronco
Aerostar
Sep 14, 2005 08:07 PM
Sedric
Jun 14, 2002 08:38 PM
