need some advice on head gaskets
Old May 21, 2015 | 08:45 PM
Early 1969's Avatar
Early 1969
I am rebuilding a 1976 302 to put in my 71 F-100. I have never rebuilt an engine before, so I have had to rely on friends, and publications. Well I was using a book that told me to just oil the head bolts, and torque to specs, which I did. After some looking around it seems a lot of people put sealer on the head bolt threads, at least the lower ones. So I have decided to pull the heads and do that. my question is should I put new head gaskets as well? The motor hasn't run yet, and the heads have only been on for a couple days. I appreciate any help!
Old May 24, 2015 | 12:51 PM
baddad457's Avatar
baddad457
With your block, the lower head bolts need no sealer. The lower bolts do not go into the coolant jackets. That aspect started with the 80-up 5.0 blocks. Even if you did need sealer, you can still do that without taking everything apart, all you do is pull them one at a time, add thread paste, then retorque them. You did install the gaskets correctly ? There's a front and rear to both. And if you're not sure, there's a way to check without taking anything apart. On the lower front corner of the head, there's an area of the block's deck that's exposed, if the gaskets are on right, that area will be covered by a portion of the gasket, poking out past the head.
Old May 26, 2015 | 09:53 PM
Early 1969's Avatar
Early 1969
Thanks for taking the time to reply.The day after my post, I tore it apart, and sealed the bolts, and put new gaskets on. $50.00 down the drain, oh well, at least it shouldn't leak..lol. Yeah my book was very clear about installing the head gaskets correctly. You can see in this picture that they are on right. Thanks again baddad457
Old May 27, 2015 | 03:16 AM
baddad457's Avatar
baddad457
Well "live and learn". Motor looks great. You can buy a chrome dipstick and tube at some of the local Advance/O'Reilly/Autozone to replace the painted ones you have there if you want to dress it up some more. The four long water pump bolts that are in the 12/6 o'clock positions on the two coolant ports in the block also need sealer, those intersect the block's coolant jackets.
Old Jun 3, 2015 | 04:42 PM
Early 1969's Avatar
Early 1969
trust me baddad457, I "live & learn" lot...lol! Yeah I sealed up those water pump bolts and flywheel bolts. Putting clutch & transmission in tonight. I still have a lot to do before I can start it.
mater73
1978 - 1996 Big Bronco
20
Mar 10, 2012 03:20 PM
bsiebert
Nov 21, 2010 01:30 AM
bkks744
Jun 29, 2010 05:08 AM
Sedric
Nov 11, 2002 07:50 PM
sjleslie
Sep 28, 1999 09:01 AM
