Transmission fluid
Old Mar 9, 2016 | 07:03 AM
Ford4you's Avatar
Ford4you
Transmission fluid
Hey guys just wondering what brand/weight transmission fluid do you recommend in a 1987 F.150 2x4?
Old Mar 9, 2016 | 07:25 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Impossible to know since you didn't say what transmission is in your truck. It could either use gear oil or Mercon ATF. A 2 x 4 is a board size. A 2wd drive is a 4 x 2.
Not to sound like a tool bag but there are probably dozens of threads on this topic.
Old Mar 9, 2016 | 07:33 AM
Ford4you's Avatar
Ford4you
Oops! My bad.. Yes it is a 4x2 and I believe 5 speed automatic.
Old Mar 9, 2016 | 08:43 AM
timbersteel's Avatar
timbersteel
4-speed Automatic?
Or 5 speed manual?
If it is an Automatic, C-6, E4OD, then it's regular Mercon/Dexron.
Mazda 5spd get regular Mercon/Dexron. I'm unsure of the ZF.
I believe anything older than mid 80's got gear oil.
Old Mar 9, 2016 | 08:53 AM
exranger06's Avatar
exranger06
87 F150s never had a a 5 speed automatic. If it's automatic, it's either a 3 speed or 4 speed. Either way, regular Mercon is the stuff to use. GM used the same stuff, but they called it "Dexron III." That's why a lot of the bottles will say "Dexron III/Mercon."
Mercon V will also work, as it supersedes regular Mercon.
Old Mar 9, 2016 | 09:52 AM
Ford4you's Avatar
Ford4you
I just got the truck so I don't know much about it. Noticed the tranny fluid is low and it doesn't always wanna shift into drive without revving it up alittle bit. It's a automatic and I'm pretty sure it's a 4 speed. So the merc on/dexron is what I should use? Any other recommendations for checking it? I know your supposed to drive it for alittle bit then check it.
Old Mar 9, 2016 | 10:04 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
According to an AllData TSB the recommended fluid is now Mercon V. Standard Mercon will work but at my job I always recommend Mercon V in these sorts of situations.
Old Mar 9, 2016 | 01:01 PM
jas88's Avatar
jas88
The problem I see with your recommendation is that Mercon V is about 50% more expensive than Mercon.
Old Mar 9, 2016 | 02:12 PM
POLARISrider500's Avatar
POLARISrider500
I use mercon LV
Old Mar 9, 2016 | 04:17 PM
My4Fordtrucks
Originally Posted by POLARISrider500
I use mercon LV
I believe that is the wrong fluid you are using. The replacement for Mercon is Mercon V.
Old Mar 9, 2016 | 09:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I use mercon LV
Good luck with that. It will kill your transmission.
MERCON V is the right fluid. MERCON will work, but MERCON V is superior to MERCON.
Old Mar 9, 2016 | 09:48 PM
ChRoNo16's Avatar
ChRoNo16
Valvoline Maxlife ATF should cover mercon requirements
Old Mar 11, 2016 | 04:59 AM
Jonathan Clark's Avatar
Jonathan Clark
Just check either owners manual or even on the dip stick but when checking get it fully warm and check in park wail running or it will read wrong
Old Mar 11, 2016 | 08:25 AM
Mark Kovalsky
The owner's manual and the dipstick will say MERCON. MERCON is discontinued, MERCON V is the replacement fluid.
Old Mar 11, 2016 | 12:22 PM
Da_Lariat_Chariot
That's actually not true. Go to Kragen/Oreilly and look at their Dex/Merc fluid. That stuff meets several different specs, and it will cover the MERCON spec. Not that I would use that stuff anyways, but you get my point.
