Transmission fluid
Old Mar 11, 2016 | 03:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Da_Lariat_Chariot
That's actually not true. Go to Kragen/Oreilly and look at their Dex/Merc fluid. That stuff meets several different specs, and it will cover the MERCON spec. Not that I would use that stuff anyways, but you get my point.
Actually it's quite true. MERCON has been discontinued. NOBODY makes a fluid with the MERCON spec. There are many, many fluids available that say they meet Dex/Merc specs.
When MERCON (and DEXRON) were in production Ford (and GM) certified each fluid that said MERCON (or DEXRON) on the label. Now that both are obsolete fluids NOBODY certifies them. A manufacturer could (not saying that they would....) take ANY fluid and say it is for use in transmissions that required MERCON/DEXRON. Do they actually meet the now obsolete spec? I don't know. I do know that if I use a fluid that says MERCON V on it that Ford has certified that the fluid actually meets MERCON V specs.
Old May 1, 2016 | 06:54 PM
theoldwizard's Avatar
theoldwizard
2012 Expedition 5.4L, 4wd, 6R80 transmission.
They owners manual does not specify the EXACT Mercon ATF. I believ it is eith LV or SP, but which is it ?
Old May 1, 2016 | 08:16 PM
Mark Kovalsky
Either one. Those two are interchangeable. But read more carefully, on page 360 of the 3rd printing it specifies MERCON LV.
Old May 1, 2016 | 08:41 PM
theoldwizard
Yep, I see it now !
Flame Out
Oil & Lubrication
23
Aug 9, 2010 10:28 AM
Charlie_Hustle
Feb 15, 2010 07:39 PM
inline6 Red Neck
Oil & Lubrication
15
Mar 11, 2006 05:47 PM
MeBadDog2002
Jul 2, 2004 10:30 AM
Steve0
1978 - 1996 Big Bronco
Dec 10, 2002 07:50 AM
