Rough idle, throttle does nothing
Old Mar 14, 2016 | 09:49 PM
mountain dewd's Avatar
mountain dewd
Well, I am not making very much progress as of late. When I start the truck up, it idles pretty rough. It starts easily though. The timing is (supposedly) dead on with a light and the dwell is right around 30. Weird thing is that the throttle has zero influence on the idle. It will make a sucking noise, but it won't change the rpm a bit. Distributor is a new reman unit, new points and condenser, new vacuum advance. Any ideas?
Old Mar 14, 2016 | 09:55 PM
whomrig's Avatar
whomrig
From what you describe, I think you have a vacuum leak that you need to find and repair.
the dwell as I recall needs to be 28 deg.
Old Mar 14, 2016 | 09:56 PM
mountain dewd
Thanks for the quick reply! I have sprayed starter fluid all around the manifold, base of carb, and vacuum hoses and had no indication of a vacuum leak.
Old Mar 14, 2016 | 10:05 PM
whomrig's Avatar
whomrig
are the plug wires in the correct firing order?
Old Mar 14, 2016 | 10:07 PM
mountain dewd
I am 99.99% sure they are. There were times that it ran okay, but it seemed to get worse as I fiddled with it.
Old Mar 14, 2016 | 10:12 PM
whomrig's Avatar
whomrig
try this
disconnect the vacuum hose to your power brake booster and cork it. start the engine and see if any change.
Old Mar 14, 2016 | 10:13 PM
mountain dewd
Thanks for the idea, a little late to do it tonight, but ill put it on the list for tomorrow.
MeanGreen72
Jun 16, 2019 11:31 AM
Zazoos
Oct 7, 2016 09:21 AM
pit_of_pity
13
Apr 27, 2011 02:05 PM
59pan
Aug 20, 2007 06:14 PM
Farmengineer77
Jan 13, 2005 04:37 PM
